3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Christmas Lights to Music Using Arduino
Step 7Put It All In A Box
Put It All In A Box
I started by hot gluing the circuit board into the clear plastic tub.
I had an extra powered USB hub laying around so I decided to use that to power the Arduino.  I hot glued the power adapter for the hub into place and plugged the 11th 6' extension cord (the only one not cut up) into it.  I also glued the hub in place.  Into the opposite side of the extension cord, I plugged in the circuit board's 120v plug.  The USB cord going to the Arduino from the hub is a $1 extend-able cord from Dollar Tree but any USB cord would work.
To run the cords through the side of the tub, I used my soldering iron with the tip removed (effectively a mini heat gun) to melt away the plastic.  I then used hot glue to secure the cords in place.  I did this with the lights' power cords (top of the picture below) and the power cord for the board (bottom).
I finished it up by using wire nuts to connect the power going out to all the lights to the test wires I had already hooked up (adding an additional two for the 7th and 8th channels).  Add the lid and you're all set.  Should be waterproof-enough for me and it's protected by the front steps of my RV.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:MRedmon(Matt's Photo Gallery)
