Christmas Ornament, Inside Out Turning
1,233
27
5
Published
Introduction: Christmas Ornament, Inside Out Turning
As the silly season is almost upon us , I thought it wood be a go idea to try my hand at turning an ornament on the lathe .
Starting by ripping down some scrap pine to 4 lengths by 25 mm x 25mm. They were held together with hot glue and the inside was turn . Next the 4 blanks where pull apart and glued back together , and what was once the outside now become the inside of the ornament . Once the shape was achieved the sanding started with 120 grit and worked my way up to 1200 .Super glue (C.A.glue) was added as the first coat a light sand with 000 steel wood and then the final coat was added . Im slowly getting used to what all the lathe chisels do and what not to do with them Overall Im very pleased with the end results
Please dont forget to hit the thumbs up button & share If you havent subscribed, and you like what you see .....Please subscribe
And always THANK YOU for watching
Repeat after me restoration Facebook : https://www.facebook.com/repeataftermerestoration/
Instagram : https://www.instagram.com/repeat_after_me_restoration/
Music : Will Bangs, You make my heart sing so loud
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    5 Comments
    Nice job. Its hard to tell what tools you're using but I thought I saw you using a gouge as a scraper. These youtubers are a great source of information: Carl Jacobson, Mike Waldt and Wyomingwoodturner (Sam Angelo). Also if you speak Spanish Miguel Sanchez.
    Hi Seba
    Thank you for your kind words . Yes , I have watching many you-tube clips of all the people you mention , They are all a wealth of information
    Ive only had my lathe for a month or so and the chisel you see me use ,come with the 2nd hand lathe . So im very new to turning and i really dont know what each chisel does .Im slowly learning and with time i will buy a good set of turning tools ...Onche again Thank you
    Harbor Fright cheap set of lath tools. Cheap tools all around. After you find the ones you really like then go buy the good ones.
