Christmas Tree With LED and Music, Controlled With Arduino
Published
Introduction: Christmas Tree With LED and Music, Controlled With Arduino
About: I'm an Arduino Maker, I like technology, playing tennis
In this holiday season, almost everyone has done their Christmas tree in your home, small or large. In this post, we will see how to create a Christmas tree with a few €, using Arduino. Through this microcontroller will be able to choose from several different profiles, which allow you to sing and illuminate our "tree".
What do you need?
Arduino Uno
LED
Infrared remote control
Buzzer
Box Pandore / Panettone
Felt-tip pens or watercolors
Step 1: Explanation of the Project
Explanation of the project
At the base of the project, there are several components, each with a specific goal:
LED
The LEDs are simply diodes that light up when there is a current step, typically a few tens of mA. The potential drop between the anode and cathode is typically a few volts
BUZZER
This device allows you to play the Arduino through a current flow in the device. Through the calculation of the period of a particular note, you can play it with your device. Here's the full list:
Step 2: Infrared Remote Control
This device has the task of deciding what kind of song you play. Pressing one of the buttons on the remote control, the receiver located a few meters, you can send a binary encoding to the Arduino, which establishes the point of the Arduino code to be executed.
Here is a list of the remote control code for the Arduino:
Step 3: Steps for the Realization
Steps for the realization
Take a carton of a Pandoro / Panettone
Paint it with a color of green
Arrange the LEDs around the box
Also connect the buzzer outside
Connect the IR receiver inside the Pandora
Connect the anode and cathode of the LEDs, respectively, selected PIN and to GROUND
Load the program on Arduino
You can download the program of Arduino from my Github repo
Step 4: Final Risult
As you can see from this video, the result is pretty good ! It is a very good project with Arduino !
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    I'm looking to find and build an Arduino controlled; sound activated CHRISTmas tree 200-500 LED (each seperate LED can be switch to red, green or blue) lighting system that has an audio input and\or microphone that responds to either room noise (including music being played & voice) or connect your tunes to it so that the Tree (room, whatever) responds to the sound.
