Remove these ads by
Signing UpStep 1: Prep and Supplies
Measure all the windows you want to trim. Then go to your local home improvement store and buy enough plastic lattice framing to cover your measurements plus some mistakes. This stuff isn't the cheapest but it's easy to work with and should last forever. While you are there pick up 4 'L" brackets for each window.
Supplies/Tools
- Lattice framing (per measurements)
- L brackets (4 for each frame)
- Drill (for screw pilot holes)
- Flat head screw driver
- Mitersaw or handsaw
- C7 strings of Christmas lights.
- Wire stripper, electrical tape
- Hooks,Velcro
Visit Our Store »
Go Pro Today »
Or, maybe even cut the PVC pipe in half and glue the halves in the fittings. That way, you could easily go back and remove lights if you have to. It's possible that simply gluing the fittings on would make the rectangles strong enough.
I like the plastic lattice idea but it looks like it costs about $8.25 for two four-foot lengths. With all the windows in my house, that may cost a small fortune. But half of a ten-foot PVC pipe would go a long, long way.
PVC pipe is amazingly strong and I bet I can use a dado blade on a table saw and cut a kerf wide enough to put in the lights. You could even do a plunge cut and leave an inch or two at either end of the pipe to shove into the pipe fitting. That way, there is no compromise in strength.
But, let it be known, this is one heck of a great idea you had! The only thing that may be better is to purchase replacement screens and drill holes thru the frames to insert the lights. That way, you would not need to build anything nor would you need to find a way to fasten it to the windows. And if you do not like the lights being perpendicular to the screen, you could buy some of those plastic self-adhesive light holders and paste them all around the inside of the screen to get the same effect as yours.
I am pretty curious about homemade extension chords though!!
I have to ask, is there another name for Lattice framing? I went to my local Lowes (bearing in mind that I live in New Mexico) and asked for Lattice framing. Judging by the look I got from the associate I asked I would've been just as well off saying Ziggy Zoggy Ziggy Zoggy Oi Oi Oi.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=250236-73428-73003480&lpage=none
