3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Chrome Polishing, Mythbusters Style
Step 4Gawp at the Results.
I was really blown away. In some of the pictures the flash makes it look more scratchy than it really is. I don't think I'd use this on a top dollar bike, but I hope a top dollar bike would have better chrome (and better care).
6 comments
Mar 13, 2011. 12:36 PMsunofgod says:
To protect the restored shiny chrome carefully spray with your favorite lubricating oil spray and then polish with an old cloth. This leaves a protective film on the metal which repels water. This is good for cleaning, polishing and protecting
and only takes a few moments effort every time you clean the motorcycle
to keep it looking good.
Oct 20, 2009. 11:17 AMronmaggi says:
The phosphoric acid in the cola is what does the trick. I have used regular cola without the foil on engine parts. The sugar helps hold the phosphoric acid onto the parts while soaking. After seeing what cola can do to rust you may want to try www.instructables.com/id/Homemade-Carbonated-Beverages/
Oct 29, 2009. 2:56 AMac7ss says:
Diet cola has no sugar... :)
and it would be the Carbonic acid you are referring to.
Nov 7, 2009. 7:37 PMronmaggi says:
 I was referring to what I was taught, that the sugar in regular cola helps hold the phosphoric acid to the parts your cleaning. Carbonic acid does nothing to rust. We sell dedicated rust removers that are phosphoric acid. If you read the ingredient list on most commercial colas, Phosphoric acid is right there.
Oct 29, 2009. 11:38 AMpsychotron says:
You might want to read the ingredients on cola some time...
Carbonic is a very weak acid, the phosphoric acid makes the cola "tart".
Pepsi has citric acid as an added ingredient...
Mar 29, 2009. 5:02 PMxchef95x says:
so just scrub with Dt. Pepsi and Aluminum foil? That sounds to easy, whats the catch?
Oct 24, 2009. 3:27 PMRich99 says:
that's how we did it up az\t the gm plant in tarrytown, ny., to the hundreds of cars sitting in inventory. (in the 60's)
Oct 23, 2009. 5:04 AMt.rohner says:
The catch is that i will rust immediately when it comes in contact with water.
Those spots that rust, are pinholes in the chrome coat. By this or other polishing methods you remove the rust and then you you have the bare steel on the surface. You'd need to clear coat it, but there are not too many clear coats, that can handle high temps on exhaust pipes.
Jul 31, 2011. 7:12 PMLeona3000 says:
When you remove rust with phosphoric acid, you are converting it to a compound with a single oxygen atom. It's black, and inhibits rust. Unless the pits are severe, it won't rrust easily
Oct 23, 2009. 9:59 AMPhoghat says:
Hi Temp engine paint is available in colors, shines nicely, and gives a custom touch (black for eggsample)
Oct 24, 2009. 7:11 AMPhoghat says:
Why no, it wouldn't be. But, given the choice between shiny slightly scratched chrome and a color which looked custom, I think I'll take the color.
Oct 25, 2009. 12:21 PMt.rohner says:
There are other chrome plated parts that don't get hot... it may be helpful for that.
Oct 22, 2009. 10:09 PMold n grumpy says:
Aside from a little elbow grease what makes this method better than chrome polish ?
Mar 21, 2008. 10:48 PMtcase says:
I used to work for a company called PinWall cycles. We just used the extremely fine steel wool I always told them they were putting fine scrathes into the metal, but they didnt listen. this sounds better, I'll keep it in mind.
Aug 20, 2007. 3:22 PMZak says:
Aluminum foil probably gives an electrolytic effect like it does on slver, removing the rust without the need for rubbing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Captain Pedantic
