loading
Build this lovely DIY Chunky Farmhouse Coffee Table
Materials List:
4 - 4x4s @8ft
2 - 2x4s @ 8ft
2 - 2x6 @ 8ft
3 - 2x10 @ 8ft
Cut List:
4 - 4x4s @ 16"
4 - 2x4s @17"
2 - 4x4s @ 19" (45 degree)
4 - 4x4s @ 8" (45 dgree)
3 - 2x6s @ 33"
3 - 2x10s @ 36"
2 - 2x10 @ 27"
Step 1: Step 1: Make Side Braces
Attach the 2x4 brace (17") to the 4x4s (16") using a Kreg Jig on a 1 1/2" setting with 2 1/2" pocket hole screws to attach along with wood glue. There should be a 2" spacing from the 2x4 brace and the floor. Repeat step fo rthe other side of the coffee table base.
Step 2: Step 2: Attach Top Brace
Attach the top 2x4 brace (17") to the 4x4s using a Kreg Jig on a 1 1/2" setting with 1 1/2 " pocket hole screws to attach along with wood glue. The top 2x4 should be flush with the 4x4s. Repeat step for the other side
Step 3: Step 3: Attach X Brace
Attach the 4x4 brace (19") to the 4x4s using a Kreg Jig on a 1 1/2" setting with 2 1/2" pocket hole screws to attach along with wood glue. The 4x4 brace should be cut at a 45 degree angle. Repeat for other side.
Complete the X brace by attaching the two additional 4x4 braces (8") to the 4x4s using a Kreg Jig on a 1 1/2" setting with 2 1/2" pocket hole screws to attach along with wood glue at a 45 degree angle.
You should have two completed coffee base sides.
Step 4: Step 4: Assemble Bottom Shelf
Assemble the bottom shelf by attaching the three 2x6 braces (33") together using a Kreg Jig on a 1 1/2" setting, with 2 1/2" pocket hole screws to attach along with wood glue.
Step 5: Step 5: Attach Shelf
Attach bottom shelf to the bottom 2x4 braces on the two base sides using a Kreg Jig on a 1 1/2" setting with 2 1/2" pocket hole screws to attach along with wood glue.
Step 6: Step 6: Assemble Top
Assemble coffee table top by attaching the 2x10s (36") using a Kreg Jig on a 1 1/2" setting with 2 1/2" pockethole screws to attach along with wood glue.
attach 2x10 bread boards to th eassembled 2 x10s using a kreg jig on a 1 1/2" setting with 2 1/2" pocket hole screws to attach along with wood glue.
Step 7: Step 7: Assemble Table
Attach tabletop to the assembled base using 3" wood screws.
<p>Gorgeous work! </p>
Beautiful table! Well done
<p>Looks great. Can you give some information on how you did the distressed paintjob on the legs? </p>
Use 220-grit sand paper to sand the edges as desired!
<p>I like it...nice job!</p>
<p>Thanks!!</p>
About This Instructable
3,352views
105favorites
License:
Bio: Established in Oct. 2016, Handmade Haven is an outlet for sharing woodworking projects, DIY, creative crafts and more.
More by smashingdiy:Mirrored Vanity Desk Handmade Corbel Roman Numeral Clock
Add instructable to:
