3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cicadaboom - 8 step sequencer and a simple synth
This instrument is easy to build and fun to play with.
The Arduino (I'm using duemilenova) in this instrument is acting only as a power source and as a simple timer, so if you don't have one you can still build this instrument with other timer sources, like 555 for example.
I took the simple Blink sketch and changed the delay to 100ms.
The timer is connected to the 4022 while each of its output connected to a 10k pot and a switch and from there to the VCO of 4046.
The output wave is square.
The samples:
cicadaboom111.ogg - clean recording. On the 1:28 minute you can hear what happens when the 4046 pin 5 is not connected to the ground.
cicadaboom222.ogg - the sound is going through an effects software, Rakarrack.
cicadaboom333.ogg - the sound is going through an effects software, JACK Rack.
Step 1Parts and Components
Components:
- Arduino or any other timer, for example 555
- 4022 Octal Counter with 8 Decoded Outputs
- 4046 PLL
- 8X 2N2222 NPN Transistor (or any other NPN for switching)
- 8X 10k potentiometer
- 8X push buttons
- 4X 470n capacitors
More stuff:
- Audio socket
- Breadboards
- Jumper wires
- a plastic box
7 comments
Apr 16, 2012. 6:28 PMnils311 says:
I'm still trying to work out how to wire a 555 instead of the Arduino. I want to build this, and the 555 is a more feasible option for me. I do love the sound on it either way.
Jan 14, 2012. 10:01 AMOrion1615 says:
I'm also interested in how you'd use a 555 timer circuit for this sequencer! it sounds awesome and i'd like to make one without using my arduino... Would it be hard to change the 555 and arduino clock for a Midi clock signal?
Aug 10, 2011. 5:36 PMFuzzyStefan says:
hey, im exited about this! ive been looking at TB-303s, and am in love with my APC, (a 555 instrument) could you give me more directions on how i would build it with a 555 chip? thanks! great job
Apr 29, 2011. 8:59 PMijordison says:
Hey do you have a higher resolution image of this? I'm planning on building this and I'm a little unclear on where the eight lines attach to the 4046. Are they all on the same pin?
Also, what's the clock frequency you're getting from the Arduino?
Apr 30, 2011. 2:04 PMijordison says:
You, sir, are a gentleman and a scholar.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:nivini
