So what follows is an instructable on how to build a press and get from apples to scrummy scrumpy with as little cost as possible.
i took a few tips and ideas from the following sources, thanks to all those who published 'ibles already.
Homemade cheese and cider press
hard cider from scratch
Making Your Own Cider
and many more
also before i forget check your local laws for brewing in your area. its usually legal if you're of legal drinking age and you're only brewing a small batch.
Hard cider is of course alcoholic so please drink responsibly homebrew is not just about making bucket loads of cheap booze its enjoying the satisfaction of tasing something youve made yourself.
As with any homebrewing, results can vary wildly! in worst case scenarios you can end up with nasty infections or otherwise spoiled produce. sanitation is key but things can still go wrong, dont come whining to me if your cider gives you the runs !
Remove these ads by
Signing UpStep 1Equipment list.
For the press
- Wood - i used the cheapest 2"x4" for the struts and spare MDF for the plates
- An old plastic tray
- A car jack. scissor jacks work great but the oldschool cartoon style ones work too
- food grade bucket/s to catch juice in
- Tools - tape measure (and set square ideally)
- Power tools - saw, drill
for the juicing
- Apples - i got a gallon of juice from a BIG bucket of apples
- A bucket and spare clean plank to crush apples in
- Muslin bags. mine were a bit loose weave, clean tea towels would work well aswell
- funnels and filters to strain juice
For fermenting
- a demijohn (a carboy to americans) x2 if possible. Other vessels will work so long as its food grade!
- an airlock (better a propper one than a hose and bucket of water)
- sanitiser (some people use diluted bleach but the stuff from the homebrew store is cheap)
- campden tablets (not essential but advised by many)
- Cider yeast (easy enough to get in the UK but champagne yeast is supposed to work well aswell)
- Yeast nutrient, a hydrometer, pH strips and brewing sugar is good too but not essential
I am a first time brewer, and I decided (due to the recommendation of many brewers) to try three micro-batches the first time. Though the suggestion was to use multiple types of apples, we have Haralson trees in our back yard, so I used those for the juice.
After sanitizing the equipment, I filled each of my three gallon carboys with juice from the apples, added 1/2 tsp of pectinase, and a crushed campden tablet, with varying amounts of added sugars (as per other suggestions online).
Question 1: After I added the campden tablets, I covered the carboys (sealed); campden tablets release SO2, which is what kills the microbes. . . was I supposed to not cover them during this step?
For the sugar added, each of my containers were as follows:
A: 1 cup white, 1 cup brown sugar
B: 1 cup white, 1/2 cup brown sugar
C: 1/2 cup white, 1 cup brown sugar
I did not check the pH/gravity of the solutions, as I did not have pH strips, or a hydrometer.
After 2 days, I pitched the yeast (using a Wyeast sweet mead/cider yeast) into each of the 3 containers, after letting it sit for 3 hours (as per instructions) and confirming (by inflation of the bag) that it had been activated.
By the next morning, container C was bubbling at a noticeable rate (about 0.2 hz bubbles), while the other two had no pressure differential (as noticeable per an S airlock). After another day, I pitched additional yeast into both A and B, and waited a day to check them. (at which point C was at about 1 hz bubbles)
A day after the additional pitch, B has started bubbling at a rate of about 0.01 hz (almost unnoticeable) and A has yet to move.
Question 2: What could be causing A or B from taking the cultures?
(A few notes:
I pitched C first from the premade packet, which was made to treat 6 gallons, then B, then A;
though I had shaken the packet of Wyeast yeast, it sat for about 50 seconds before I pitched it;
the packet included nutrient for the yeast;
As I stated before, the S airlocks were in place immediately after the campden tablets were added;
My concerns were mainly that maybe SO2 was still in the environment when I pitched, and that maybe either the yeast or the nutrient in the packet was not evenly distributed through A, B, and C, though an even amount was delivered from the packet to each, due to quick separation (I haven't looked into their relative densities, or anything))
Thank you for your help! ~Steven
I have been distilling, making wine & beer, for about 40 odd years. Easy extraction of fruit juices, etc, is obtained by freezing, thawing, and pressing. This process ruptures the cell walls, and results in a high recovery rate. Cheers. AR10NZ
if you liked this, check out my new brewery build here!
Disclaimer: don't use mouldy bread in an old sock.
http://en.wikipedia.org/wiki/Pruno
Politically incorrect?? You misunderstand.
" ...from Press to Pi**ed", is: ..from Press to PIe-eyED. Pie-eyed of course being the colloquial terminology for drunk.
I think that Chard showed remarkable genteel sensitivity.
That is commendable don't you think?
For anyone who decides to do this from store bought clear juice, you can skip the racking at 2 weeks and just bottle after 4-6 weeks.
Keep brewin', keep drinkin', keep pissin'.
-AB
