Cigar Box Amplifier Case Mod by paulbsa
Step 9: Attach the battery connector
If the amp you used had a snap connector attached to the wire, and you were able to save it, congrats, you can skip this step. If not, and your amp was like mine, you now need to attach the new 9 volt snap connector.
The wires on these are small, probably 22-24 gauge. You could solder the wire from the new connector to the power lead wires that you cut earlier, but I used small crimp connectors with electrical tape. tape each crimp connection separately then tape them together. Unless you have an oddball amp or connectors, matching red to red and black to black should work just fine. If it doesn't, reverse them.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
