I decided to make a slightly fancier guitar than most, with real guitar tuning pegs, a nice stained and varnished finish, and a piezo pickup. You might see some photos of my homemade banjo, since I built both around the same time.
A little history: cigar box guitars have been built since the time of the American Civil War, but they first took off in popularity during the Great Depression of the 1930s. Blues musicians especially favored the small guitars, along with cookie tin banjos, washboards, and other improvised instruments. During today's economic woes and the rise of the DIY and Maker movements, musicians and hobbyists have revived the art of building and playing cigar box guitars.
Remove these ads by
Signing UpStep 1What You'll Need
~Cigar box - $1
I got this one at a garage sale. If you make friends with a cigar smoker or tobacconists you can probably get this for free.
~1" x 2" x 3" poplar board - $3
keep in mind that these are actually 3/4" x 1 1/2"
~Guitar tuning pegs (3) - $4
These usually come 6 to a pack for about $8, so you can make another guitar with the other three!
~Guitar strings (3) - Free!
I had some old nylon strings lying around, so I used the low E, A, and D strings. You can also use fishing line, steel wire, or plastic string
~Copper sheet metal - Free!
This is used to make the tailpiece, the part that holds the strings on the bottom. I found some while dumpster diving at a construction site. You could cut apart a tin can if you can't find copper
~Wood glue - $3
~Wood stain (optional) - $4
You can use any color; I choose a reddish brown. A little can'll do ya!
~Spray varnish (optional) - $5
I used semi-gloss.
~Piezo buzzer and guitar plug (optional) - $4
This gives you an electric cigar box
Tools:
~Hand saw
~Coping saw or jig saw
~Drill with bits
~Rough file or rasp
~Sand paper in various grits
I used between 60 and 400 grit, although 100 and 200 would work fine
~Clamps (or heavy things)
~Various hardware (screws, small finishing nails, etc.)
~Soldering iron (for connecting the piezo buzzer)
i have been collecting parts for three of the CBG and almost have everything i need but our are going to be acoustic and maybe upgradeable to electric
i am going to sit down with my two grand kids and we are each going to make one for our self selves
i think they mite like that and maybe be happy to play or make more instead of watching their games or TV
thanks for another instructable that will help me get this done
I'm starting to make my first CBG and will be posting it all on this blog
dirtyguitarguide.com
http://www.daddy-mojo.com/models/6-string.html
What do you say? Even some pictures and an outline would be great!
Great build on this guitar too. Keep it up!
what ends of the output jack did you attach your piezo to, I am having problems with that.
When the piezo vibrates it makes a vibrating electrical signal in the wire, ie positive/negative, on/off. The amp amplifies this signal and outputs it to the speaker, making it vibrate at the same speed as the piezo.
The only time that polarity really matters is when you're making a humbucker magnetic pickup, but that's a whole 'nuther story.
I've been trawling ebay and most seem to be $10^ for cruddy plastic ones. Yours appear to have metal caps on the end?
I should give some credit to Shane Speal and other CBG makers out there, but mine is rather different than Make's design.
