Cinder Block Bed Frame / Storage Bed
6,130
25
5
Published
Introduction: Cinder Block Bed Frame / Storage Bed
For around $100 you can build this high bed with storage clearance of either 6", 8", 12", 14" or 16" depending by what kind of cinderblock stones you use.
I used (2) 6" high cinder block stones providing 12" clearance. Perfect fit for a Banker Box!
Step 1: Buy the Supplies
Buy:
  • (2) 4'x8' MDF Boards and have them cut in sizes you need. The wood you choose of course is preferential.
For Queen Size 5' x 7' I had to cut 5' x 3.5'
  • Buy 10 Cinder block Stones for a Queen Size. (Again, depending on how you want to place the stones you may even buy more. But 10 is minimum.
  • Gripper! Looks like white paint but is thicker and prevents the stone from brittling off and gives any color put on top of it the true hue.
Step 2: Sketching or Drawing Up a Plan Helps Big Time
Step 3: Paint Every Surface Area With Gripper
Gripper helps the stones from not brittleing off as well as giving whatever color you paint it, it's actual hue. Red looks red on the gripper but would've been a dark crappy red without it.
  • Drying time is about a Day.
  • Then start with your color Paint
Step 4: Paint the Stones
Step 5: Cutting Corners (preference)
  • Place a blank Paper under your bedspring
  • trace the bedspring rounded corner
  • take paper out from underneath bedspring and tape to MDF board
  • use an xactro knife or a sharp object to poke holes along the line thru the paper onto the board
  • remove paper and connect the dots
  • use a saw to cut the corner off and sanding stone to round them smooth
Step 6: Paint the Board Edges
Step 7: Grip Shelf Liner Place Mats
  • Get the grip shelf liner and cut in pieces (1 or patchwork) to cover top of each stone also in between stones!
    (It will protect the paint and also prevent sliding)
  • Place stones to final position
Step 8: Finishing the Frame
  • Put the boards on top of the stones (may require 2 People!)
  • Don't push or pull because it will move the place mats out of place
    (if you're only one person, lay on your back in the middle of the stones and use all hands and feet lifting the board on top of the stones.)
Step 9: Adding Lights
The first lights I had used was red rope lights taped to the MDF board with clear tape. But it was too much red!
But then I found the SMD 5050 RGB LED Lights on ebay (11 feet) with 44-key remote!
  • what you'll need is adhesive velcro strips. (2cm for the MDF board I used)
  • tape the soft part around the MDF boards. Cut the strip where the boards separate.
  • the rough velcro part, cut in small 2" or 3" long pieces and width according to your LED strip (1cm) and tape the rough pieces to the LED strip. I taped mine every so often (6" or 10"). You could run the rough velcro along the entire strip but that would be hard cutting it lengthwise as the strip is only 1cm wide.
Step 10: Quality Control: Does Your Pet Like the Bed?
If not. You suck and you need to rebuild it!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    How much Gripper did you used for the cinder blocks? I am doing a twin bed with 12 16x8x8 blocks and 6 8x8x8 blocks. Also how much paint?
    5 Comments
    Hi Diana! I love this. It solves at least 3 problems that I'm facing- storage, getting up a narrow spiral staircase to the 3rd floor, and sturdy! I have two questions: Does it creak? And, how have the rubber mats held up?
    very nice I've been looking for indea for a platform bed. I'm going to try this.i bought a cal king and it don't fit into my old frame is for a queen. thank for sharing this with us
    Sorry I just saw this! You're so welcome! I'm very proud of this piece. And remember you can vary the stones for different heights. It's super sturdy. I'm still in love with this 3 years after I made it. Glad you like it!! :)
    Looks good :) I always love solutions that allow for extra storage space!
