Introduction: Cinderella Scarecrow! Happy Halloween!
a mix of Cinderella and a scarecrow! I had a lot of fun with this! I hope you enjoy it too!
Step 1: Outline
Taking a white eyeliner outline where the button and the mouth will be.
Step 2: Base
Taking a lot of white body paint and a little brown mix it together to get this light brown color for the base. Fill in your face leaving the button and mouth clear.
Step 3: Eyebrows
Taking a yellow cream makeup fill in your eyebrows to make them look blond.
Step 4: Mouth
Fill in the mouth with black body paint. I have one open side with jagged lines, on the other side in going to put string so be sure to leave some lines clear for that.
Step 5: Mouth Detail
Using white body paint I filled in the string, then getting brown and black eyeshadow I made it appear add though it was going into the skin with fake shadows, and I also did that on the ripped side to appear add though it has a smile line.
Step 6: Eye Makeup
Using a maroon color I put that in my crease , then I placed a light pink on my lid, I used black eyeliner for a double wing, and also added mascara.
Step 7: Button Base
Fill in the button white, then use a brown eyeshadow to go around the side to make it appear add though it's sitting above the skin.
Step 8: Button Detail
Fill in the button with light blue then go around the outside with dark blue and blend it in. Then using black body paint add the four dots in the center, using white body paint make the string inn the center (make an x) then last I added some black eyeshadow on the bottom for more of a shadow.
Step 9: Scarecrow Texture
Using brown body paint drag that in one direction all over your face (pat it with your finger) then use white body paint in the opposite direction. do this all over.
Step 10: Body Base
Using that same light brown cover your body leaving the dress part clear.
Step 11: Dress
Taking a light blue body paint will in the dress, then add a light blue shadow on top then around the sides put a dark blue shadow and blend it in.
Step 12: Dress and Detail
Using a light blue paint I filled in the sleeves. Then using a few different brown shadows I made fake cleavage.
Step 13: Detail
do the same detail for the skin texture then use a dark brown shadow to contour your collarbone.
Halloween Costume Contest 2015
Epilog Contest VII
