Introduction: Cinnabon Cinnamon Rolls
Hopefully you have had a Cinnabon cinnamon roll at least one point in your life, if you haven't, definitely see if you can find a Cinnabon store around you. Some Burger King's do have Cinnabon cinnamon rolls, but there is just something missing from the ones you get at Burger King compared to the real ones you get a Cinnabon store.
The recipe I have created, I worked on for about a dozen batches before I was able to get it just right.
I will warn you these do take a few hours to make (about 4 hours total), but they are just as good as the ones you get in store.
Step 1: Ingredents
You will need the following for the cinnamon roll dough:
1/4 cup warm water
2 1/2 teaspoons yeast
1 tablespoon of white sugar
3/4 cup warm milk (110 degrees F/45 degrees C)
2 eggs, room temperature
1/3 cup margarine, melted
4 - 4 1/2 cups bread flour
1 teaspoon salt
1/2 cup white sugar
Here's the list for the cinnamon filling:
2 cups Dark brown sugar, packed
4 tablespoons ground cinnamon
1/3 cup butter, softened
And finally the cream cheese frosting, this was the hardest part to perfect (I usually end up making a double batch):
1/2 cup butter, softened
1 teaspoon vanilla extract
1/4 teaspoon salt
1 (8 ounce) package cream cheese, softened
2 2/3 cups confectioners' sugar
Step 2: Mixing and Proofing the Dough
- Mix the water, yeast, and sugar. Let sit for 10 minutes to make a slurry.
- While the slurry is forming add the dry ingredients for the dough together in a mixer with a dough hook.
- When slurry is done add all remaining wet ingredients to the dry ingredients, mix for 5 minutes.
- Put the dough in an air tight container and let double in size (about an hour)
Step 3: Rolling and Filling the Dough
- Roll dough into a 16x21 inch rectangle (about 1/4 inch thick).
- Spread dough with 1/3 cup butter.
- Sprinkle evenly with sugar/cinnamon mixture.
- Roll up dough and cut into 12 rolls.
It will be a little tough to start rolling up the roll. As you roll it up lightly tug on the roll to slightly stretch the dough to help hold it together.
Step 4: Baking
- Place rolls in a parchment paper lined 9x13 inch baking pan. Let them rise until nearly doubled again (about 30 minutes).
- After they are done rising for the second time, remove the rolls and preheat the oven to 385 degrees F (200 degrees C).
- Bake for 15 minutes while the entire pan is covered in aluminum foil.
- After 15 minuets remove the foil and bake for an additional 3 to 4 minutes to lightly brown the tops (watch it they will brown quickly!).
Step 5: The Frosting
You will need to add the ingredients for the frosting in precisely this order:
1/4 teaspoon salt
- When you first put the butter in make sure it is at room temperature, and after it is been whipped for about 2 min. you will need to put the bowl in an ice bath to lower the butter down to right around 45°F. As soon as the butter has stiffened up just slightly, whip it with the mixer again and you will noticeable fluff up significantly more this time.
- While the mixer is still running, add in the vanilla, salt, and the cream cheese and whip for another 2 min.
- After everything is been incorporated add in the confectioners' sugar 1/2 cup at a time.
Step 6: The Final Touches
As soon as the rolls come out of the over put a glob of frosting on each of the rolls and put it back in the over for 1-2 minutes to lightly melt some of the frosting and let it seep in between the rolls.
Let cool for 10-15 minutes, then enjoy your warm homemade Cinnabon cinnamon rolls.
If you let the cinnamon rolls come down to room temperature you will be able to freeze them for up to three months in the freezer, as long as they are in an airtight bag.
Even though these take a while to make, the taste is exceptional and you will never be able to eat another cinnamon roll out of a can again!
Runner Up in the
Copycat Recipes Contest
