_______________________________________________________________________
Though there are many Instructables on some aspect of how to make circuit boards, this one is different. It's an instructable on how to make the things you need to make circuit boards, specifically, a flamboyant business card toy. Over the past six months I have set up fairly complete printed circuit board fabrication lab in my apartment, cheaply and safely, and I intend to cover all aspects of the process, from start to finish. Some of it you may have seen before, but here it is all in one place, with references.
All in all, I had to design and build an airtight etch tank out of laser cut acrylic, an SMD vacuum pickup tool, a reflow oven and temperature controller, refine the toner transfer process with a modified laminator, build a custom programming jig, and of course design, program and build from scratch every aspect of the thing I did all this for in the first place: my business card. In the end it was well worth the time to have the ability to make circuit boards appear in my hands in an evening.
The POV Business Card uses the classic persistence of vision optical illusion to flash your name and number in midair as you wave the card. Based on the PIC12F508, an 8-pin 6 I/O ultra-low cost microcontroller, it is entirely surface mount and extremely thin- it uses PCB laminate that is as thin as a standard business card. And at roughly $2 apiece in parts, depending on how good you are at sourcing components, they are cheap enough to hand out (to the right people).
But why go to all this trouble simply to make something to give away to someone I just met? Why not just have them printed up in an afternoon for less than 10 bucks at Kinko's? Why, because I want a card that would not get thrown out. A card that would embody exactly what I do, instead of clumsily trying to sum it up in an clever job title. A card that would get me places.
The Scenario
Picture the following scenario, if you will: you have just met someone who you need to know. In actual fact, they need to know you. Having exchanged introductions, "The Man," complete with dark suit and power tie, casually hands you his cloned, company-issue business card.
"Here's my card," he grins, knowing that you will impressed by his Ownership Of Card, or at least his Power Over Someone Who Owns An Embossing Machine .
Probably he expects to see you to scribble your number on a torn scrap of paper. But when you reach into your pocket and pull out your card, certainly he doesn't expect to see... your name glowing in midair, floating before his very eyes!
"It's called persistence of vision," you say, as you hand him your card. "I make these in my basement. From scratch."
You didn't even need to say another word; anything more would just be gloating. You can see the look in his eyes; he's already sold.
"Look at that subtle off-white coloring. The tasteful thickness of it. Oh my God, it even has a watermark."
- Patrick Bateman, American Psycho
Disclaimer: I should note here that this Instructable involves a lot of things that could be dangerous if done without caution and informed planning, including fire hazards, risk of electrocution in various horrible ways, handling of nasty chemicals, and very toxic fumes. This one really has it all, folks. So be safe!
Remove these ads by
Signing UpStep 1Design an Etch Tank
For those new to this, you need an etch tank to hold the acid you use to eat away the copper on your circuit board that is not covered in some kind of etch resist. It can be pretty nasty stuff, depending on the kind of acid you use, and you need to safely contain it if you plan on doing this both regularly and in the house that you live and breathe in. Or anywhere near your kitchen sink. This is doubly important if you plan on storing it for any amount of time, though to be sure this not a safe permanent storage container.
The Design
The tank should be airtight, with a secure lid, have an air inlet for a bubbler, to agitate and oxygenate the solution, and an air outlet to a house that will vent out the window. I also added a check valve to the air intake on the tank so that any exhaust gases stay out of the air pump. It should hold the board upright for the minimum amount of acid, and it should be opaque to light so that the solution does not degrade from exposure to the sun. However, I left one side clear so I can look at the board to see if it is done etching, and also because it looks cooler that way.
I designed my tank for a total volume of roughly 2 Liters, planning on filling it to only 1.6L to leave room for the air bubbler and hose, the board itself, and a little extra for a safe lip on the top. The 1.6L value was determined with the figure of .016 liters per cm2 of board area as reported here. Assuming a a, 8x10in double sided PCB with 50% coverage of 36 μm ("1oz") copper.
For reasons I'll elaborate on later, I chose to use Cupric Chloride (CuCl2) as my circuit board etchant. CuCl2 is corrosive to most metals, and a few plastics.
When researching the materials you plan on using, datasheets abound under the search terms "xyz chemical resistance." Understanding the properties of materials is critical in engineering something like this, so plan ahead. Finding out that a hose melted in your acid bath and contaminated the solution, and then having to fish out each and every little tiny chunk is no fun.
Very few things will survive highly concentrated acids forever. We aren't using anything highly concentrated,as far as these things go, but the effect is the same; it's acid-resistant, not acid proof.
The following materials are generally safe to use for the construction of the tank:
- Polyethylene (PE) and High Density Polyethylene (HDPE)
- Polypropylene (PP)
- Viton
- EPDM
- Teflon
- Glass
- Acrylic
- Polycarbonate (especially mar-resistant polycarbonate)
The following are definitely NOT safe, and should be avoided anywhere directly exposed to the solution:
- Any metal (except titanium!)
- Nylon
- Silicone
I have found it much much easier to use, no mixing or heating needed.
Works faster too.
It is more expensive though, but has lasted me a while.
Great work, I am actually making a similar POV to teach others to make PCBs on their own.
Thanks and good luck!
Do you think there is a danger with my method of cooling too fast and having some ill effect? It sure is easier.
If you are making a thousand of something to tight tolerances, then the failure rate and inconsistency are unacceptable, and it's worth the time. If you are making 10 of a thing, and have the time to QA every one, then the skillet is probably easier. If it works, it works.
My setup is probably overkill for most home SMD projects. I'd even say it was overkill for my projects. :) As it's been said before, overkill is a way of life.
I took a look at the 12F508 Datasheet, but didn't get it.
Thanks & Congrats !
Cheers,
How come you guys bake potatoes? make pizza, toast bread cheese and tomatoes, bake frozen chiken, pre-heat hotdog buns, broil a bunch of half garlic and olive oil, bake tomatoes, hot sandwich, etc?
You might be able to take a regular vertical toaster with side heating elements and place it on it's side. I don't know how hot those can get, but it may be close. It would need to be sealed with a door somehow. And you'd need to find out what the regular operating temperature and wattage was so you didn't exceed that and start a fire.
Also, if you don't need your design in massive quantities, you can just go over the board with a hot air soldering gun and get similar results. Even a regular pen type soldering iron works, with practice.
Just don't do anything I wouldn't do!
"volatile control unsigned char TRIS @ 0x006;"
Thanks for the instructable. Great Idea!!
Really great idea for a vacuum pen!
Been using water + iron for ages. Not exactly the safest method but gets the job done.
I've never done any surface mount work myself, but you've inspired me to rescue my electronics stuff from the yard sale pile and give it a shot. I'd maybe like to make a card that has a snap-off portion that will reveal a tinned connector that plugs into a USB port and has some digitally stored goodies, like a copy of my resume and some pics and videos of me doing my stuff. Probably too expensive and complicated to be practical, but it would sure be slick if I could pull it off.
Honestly, this instructable could be a book if you wanted to flesh it out a little. Anyway, great job!
Adding USB capability is a feature many have recommended and I will certainly add in future variants of this thing; it would be so much more versatile if it could be programmed by anyone with a computer.
Alternately, your idea of what amounts to a flash drive on a board could be easily accomplished simply by buying up cheap 256 MB USB flash drives from five years ago. I bet you could get them for under a dollar if you found old stock. The work would all be done for you! Then just pull them out of their housing and cut out a slot for it to fit into out of card stock with your name and logo.
A very well written . . . and very complete Instructables.
A job well done.
You made one error though, in the intro. You state-"It's called persistence of vision," you say, as you hand him your card. "I make these in my basement. From scratch."
It should read-"It's called persistence of vision," you say, as you hand him your card. "I have these made in a third world country with no EPA over sight by children that I pay 2¢ an hour. The shipping is free"
NOW you have a capitalists attention.
Really though, thanks for sharing the smarts, this is right up my alley.
And you're welcome! I had fun doing it.
You don't need ANY of the things described, and it is in error to claim things like nylon or silicone are "not safe".
A 2 liter tank for something business card sized is crazy.
Otherwise it is a nice project, the writeup on it is just all wrong.
Wrong in what way? In the sense that you would do it differently?
Of course none of these things are really necessary to make a single PCB. But when you start talking about 100 of them in a night? You need to refine the process to make it economical. This is not a cat litter box in the mom's back yard, and to say that shouldn't be improved upon is foolish.
Further, have you looked at the chemical resistance of those materials? Both nylon and silicone will effectively either crack or dissolve when in an atmosphere of cupic or hydrochloric acid. Be aware that what I am talking about here is a long term storage solution that be used every day with the windows closed. I have had plastic fittings melt and break in my acid bath, and I would call that "not safe".
You might have noticed that I made the carrier board hold 6 PCBs on one; besides, it just foolish to think I made all this for this one project, or even a single business card. I use this for every board I ever need to make. The 1.6L value was determined with the figure of .016 liters per cm2 of board area as reported in Etching with Air Regenerated CuCl2, linked above. Assuming a a, 8x10in double sided PCB with 50% coverage of 36 μm ("1oz") copper. This means there will be enough solution for the air bubbler to regenerate it as it is etching. It is not just for agitation.
Do it once and do it right.
That's why my pizza oven is 5000lb and my brewery is mostly stainless steel...
Incidentally, that would explain why I did not get the bond I wanted. I had intended to use Weld-on 16 but wasn't able to get any in time, and had to use some pure methylene chloride.
