3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Complete Circuit Board Lab & POV Business Card
Step 7The Toner Transfer Process
  • last photo ←
Laminator in hand, now we need to use it. This is the first step of actual PCB fabrication; everything else was just foreplay.
Finding Suitable Transfer Paper
_______________________________________________________________________
The first step is to print a transfer onto suitable paper. If you are sufficiently bankrolled, you could use the commercial product made by Pulsar Pro , at about 10 cents a sheet, or if you're feeling thrifty you can go the DIY Route, which is free. I don't know why I would even question that, though. Sorry.
Finding the right free paper can be tricky. The two key characteristics are its ability to hold on to the toner when printed on and its ability to release it when heated. One predictor of this is how glossy the paper is; more glossy, better release, less glossy, means better hold. We need a happy medium.
People on the internet will recommend all kinds of weird store brand glossy photo papers that are long discontinued, or have to be imported from overseas. Some people have had success using the waxy backing on shipping labels, suggesting you buy them and then peel off all the labels(or use all the labels and then save up the backing). Moreover, most papers are associated with the need to rub and peel and soak the boards just to get the paper off.
Forget that. If I am going to compromise it has to be actually free, not just less expensive than the real thing. I have tried many, many things. As it turns out, it was a piece of junk mail that did the trick; a Menard's coupon mailer gave me the best results out of everything. Eventually I stopped getting the junk mailings, and they only had a few strangely sized pages each, so I had to find a more consistently available paper. But I knew where to start. The best analogue so far are those glossy Apartments For Rent listings they have at the grocery store. Check out the free literature rack for something similar. It works remarkably well; it prints without toner loss, and when you run it under hot water, it releases instantly. Presto!
The paper is too thin to run through the Laser printer by itself, so you need to make a carrier out of regular white paper by folding over and creasing the top of one side.
The Laser Printer
At this point I should mention the printer itself. For the most part, your final resolution, board quality, and minimum feature size is limited by the resolution of your printer. In all other respects, any black and white laser printer will work as well as any other. Toner density should be set to the maximum level, and hopefully you have a printer that has a single-page slot in it so you can just feed the page in by hand.
You could even use a photocopy using a regular inkjet as the source if you can figure out how to load your special paper; any toner based method will work.
One caveat, that I discovered too late: the standard Brother brand toner reputedly melts at a higher temperature than other kinds of printers, so I had to get an off brand refilled cartridge that uses a more common toner to get consistent results. So far so good, though. It was a cheap fix, given that I specifically had to buy the off-brand stuff.
Transferring the Pattern to the PCB
To prepare the PCB, you will find that you need to have it very clean for the toner to stick to the copper. Even fingerprints will pose a problem in the final adhesion, so wear cotton gloves. Acetone or isopropyl alcoholor even just soapy water and a scouring pad work well,. When it's clean, wipe it down with a lint free cloth and let it dry.
The PCB i have available is thin as far as FR4 goes, at around .020 in (20 mil), and that is exactly what I want. Thinner PCB not only goes through the laminator, but can be translucent Standard PCB
Once the transfer is printed, you need to line up your precut PCB to your alignment marks on the transfer paper, toner side to the copper. Here it really helps to have a light table so you can see though the transfer paper. Fold over one edge of the transfer, crease it, make sure that it doesn't move, and feed the creased end into the preheated laminator. I have not noticed any differences in adhesion based on transfer paper on the bottom roller or the top roller, though I use very thin PCB. You may notice a difference for thicker PCBs.
The technique for double-side PCB is similar, but the alignment is tricky. Instead of leaving a margin on your design to be folded over, you print the patterns for both layers side by side, with a gap that is the thickness of the PCB. The two sides should then line up exactly opposite each other when folder over the PCB.
The board is pulled through about 1/4 " per second. I usually run it though about three times, with no time for the board to cool between passes. Of course, the number of passes will vary quite a bit depending on board thickness, the kind of toner, type of paper, and laminator settings. Cotton gloves also help to remove the hot board from the laminator.
Now to the sink where a stream of hot water is ready and waiting. The paper should peel right off after about 10 seconds, though the finer details will need a quick rubdown to clean off the remaining pulp.
And it's ready to etch!
Tools & Supplies
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:sponges
