Circuit Board Manufacturing Without a Computer Part 1: the Design
5,610
185
4
Published
Introduction: Circuit Board Manufacturing Without a Computer Part 1: the Design
If you want to design and build a circuit board, but do not have the time nor resources to design it on the computer or a laser printer to print it, then this instructable series is for you. This instructable will show you how to go from the idea of what you want to build to the copper clad board with the traces marked on it with permanent marker. The next instructable will go through the process of etching it with ferric chloride. The video below will compliment this instructable and give an audio/visual explanation of it.
Step 1: The Idea
When you are designing and building a circuit board, you first want to have an idea of what the final product needs to do. In the case of the project in this instructable, I wanted to run an LED(Light Emitting Diode) using only the power from a dead AA battery, which only supplies about 1.2 volts. This is not enough to power an LED, so a voltage booster circuit or a joule thief must be used.
Step 2: Making/finding a Circuit Diagram
After you know what you want your project to do, you need to find or design and electrical schematic for it. To do this, you can either design a circuit yourself, find a schematic on the internet, or modify an already existing schematic from the internet. Once you have your schematic, you should test it on a breadboard to make sure your modifications work and that all your components are working.
Step 3: Designing the Layout
On a PCB(Printed circuit board), each component is connected by copper lines called traces. When designing the trace layout of your board, you need to first draw a scale board on your paper. You then draw the components as they actually are (not the schematic symbol) to scale on the drawn board on the paper. Make sure to put components that are close to each other in the schematic close to each other on the board. Also, make sure to include the pins of the component in your drawing. When all the components are drawn, connect the leads by drawing lines in between the pins. This part takes a lot of brain power because you have to consider all the other connections. This step may take many different tries to get the right trace layout.
Step 4: Preparing the Copper Clad Board
To prepare the copper clad board, you need to cut it to size, clean it with acetone, and sand it with fine grit sandpaper. This will allow for the best results on the final product.
Step 5: Drawing the Traces
To draw the traces on the board, you will need 2 permanent markers, one of them fine point, and one of them regular tip. I used a sharpie marker. You can the then draw the traces on the copper clad board using the design you created from step 3 as a guide. Use the two different types of permanent markers as you see fit; using the fine tip to draw low current traces and normal tip for mounting pads and high current traces. After drawing all the traces, go over them again with the marker for a second coat.
Before actually drawing the traces, draw thick rectangles as copper pads where the component pins will be soldered.
After your circuit board is prepared, move on to my next instructable on how to use ferric chloride to etch the circuit board and remove all the unwanted copper.
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    4 Comments
    nice. Before computers I alsways used to do it like that. Maybe I am not artistic enough but in the end the components on my board always looked to be placed a bit crooked, but it certainly does work. I found that not all permanent markers last against Ferrichloride, ammoniumpersulphate or H2O2/HCl when dipped long, so fresh solution seems to be best... or make sure you have a proepr permanent marker
    using toner transfer has boosted my PCB production, but as I discovered the current toner I use isnt as great (it is for printing, not for transfer) I went back to this method.
    being a bit set on neatness, what I do is I use a piece of 0.1 inch perfboard to get holes on the proper distance. I point scratch those, drill them and then connect them with a sharpie.
    I am sure people with a steady hand and a carpenter's eye dont need that but it has helped me to create pcb's that were at least no pain on the eye :-)
    For say 14 pin IC's, I know it used to be possible to buy transfer stencils that you would rub on the copper. Haven't seen those for a long time.
    Anyone know if those are still around?
    Electronics Plus still shows the Philmore (Datak) etch resist transfers for sale. http://www.electronicplus.com/content/ProductPage.aspmaincat=pc&subcat=pca Man, what a blast from the past! Nothing better than the smell of warm ferric chloride (yuck!)
    That is good to know.
    I actually still can smell that stuff, just from memory and the stains, the stains
    TT, I have made lots of PC boards using a Sharpie marker. So nice to see you showing how it is done. One think I will say, once you have you PC board etched out, before trying to solder anything on the freshly etched board, take an eraser and erase the remaining copper traces and then clean the board with some alcohol. That will give you the best capability to make very good solder joints. And if you use a little liquid flux, it will solder very nicely as well. Just a little suggestion. Keep posting.
