Step 2What Order and Which Way to Insert Components
- If there are tall components right next to shorter ones, you avoid having to bend already-installed taller components out of the way while inserting shorter ones later on.
- One of the best ways to hold a component in place is to insert it, and then lay the board upside down so the table surface keeps the component in place. If you install shortest to tallest, the tallest component will always be the one you're currently working on.
It's also helpful to install components so that the value can be read in the same direction as the surrounding text. For instance, install all the resistors with their tolerance bands on the right so that all the values can be read without having to rotate the board.
Make sure the notch on ICs matches the notch on the board.
comment
Add Comment
Add Comment
