3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Circuit bend the DS-1
Here is a 'follow up' to another DS-1 modding instructable. Those of you who are part of the circuitbending movement, or those just getting into it, will love the crazy sounds you can get by modding the pedal!
I'll admit, this is definatley NOT a mod for everyone, I just happen to think its a great beginner project and you can get some really funky sounds, some even can sound like an octave pedal.
I suggest you check the soundclips before you attempt these mods!
I hate the DS-1 pedal but you know what they say, a wall of noise is the best way to end shows! There are about four different bends, but five are listed. This is because A seems to be exactly the same as E, but it has been listed as two different mods before so there may be a difference. Disassemble the DS-1 so you can easily see the back of the circuit board and continue to step 1.
Step 1Performing the mod and adding a switch (optional)
What you need to do is solder a wire to the 'base position'. This wire is where all the variations are soldered to (see reference diagram) and solder another to one of the different positions, A through to E. Each one has a different sound!
If you want to add a switch, solder one wire to the base position and to the middle lug of an spdt switch. Then solder a wire to a point (A-E) and the other end to either the right or left lug of the switch, this way, you can toggle between having the mod on and off incredibly easily!
8 comments
Nov 28, 2010. 5:25 AMsjhaakie says:
damn i have a boss DS 2
Aug 3, 2009. 11:02 AMzleveshr says:
any recommendations for transistors or anything of the sort for this?
Aug 3, 2009. 11:00 AMzleveshr says:
If I wanted to say, connect wires to more than one of the points (a-e), would the process be the same? "connect wire to base position and then..." and all that jazz?
Mar 17, 2008. 5:43 PMDavvik says:
Does this affect the life of the pedal? And I can't get the sound clips to work, are the links still active? I'm assuming I can desolder it to reverse the affect right?
Jun 26, 2009. 5:56 PMs3th93 says:
i suggest using a toggle switch between the base point and the other solder points this will allow you to switch between the mod and the stock circuit plus youll then have 2 sounds out of 1 pedal and it hasnt affected the pedals life for me yet
May 28, 2007. 6:10 PMnagutron says:
Hey, I found a cool clip about circuit bending, for newbies like myself who were wondering what it's all about:
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/w6Pbyg_kcEk"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/w6Pbyg_kcEk" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
May 28, 2007. 6:11 PMnagutron says:
Er, Sorry. No embedded vids in comments. Here's the link:
http://www.youtube.com/watch?v=w6Pbyg_kcEk&feature=dir
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:lp_man
