High Power LED Driver Circuits
 by dan
Featured
High-power LED's: the future of lighting!
but... how do you use them? where do you get them?
1-watt and 3-watt Power LED's are now widely available in the $3 to $5 range, so i've been working on a bunch of projects lately that use them. in the process it was bugging me that the only options anyone talks about for driving the LED's are: (1) a resistor, or (2) a really expensive electronic gizmo. now that the LED's cost $3, it feels wrong to be paying $20 for the device to drive them!
So I went back to my "Analog Circuits 101" book, and figured out a couple of simple circuits for driving power LED's that only cost $1 or $2.
This instructable will give you a blow-by-blow of all the different types of circuits for powering Big LED's, everything from resistors to switching supplies, with some tips on all of them, and of course will give much detail on my new simple Power LED driver circuits and when/how to use them (and i've got 3 other instructables so far that use these circuits). Some of this information ends up being pretty useful for small LED's too
here's my other power-LED instructables, check those out for other notes & ideas
This article is brought to you by MonkeyLectric and the Monkey Light bike light.
Step 1: Overview / Parts
There are several common methods out there for powering LED's. Why all the fuss? It boils down to this:
1) LED's are very sensitive to the voltage used to power them (ie, the current changes a lot with a small change in voltage)
2) The required voltage changes a bit when the LED is put in hot or cold air, and also depending on the color of the LED, and manufacturing details.
so there's several common ways that LED's are usually powered, and i'll go over each one in the following steps.
Parts
This project shows several circuits for driving power LED's. for each of the circuits i've noted at the relevant step the parts that are needed including part numbers that you can find at www.digikey.com . in order to avoid much duplicated content this project only discusses specific circuits and their pros and cons. to learn more about assembly techniques and to find out LED part numbers and where you can get them (and other topics), please refer to one of my other power LED projects.
Step 2: Power LED performance data - handy reference chart
Below are some basic parameters of the Luxeon LED's which you will use for many circuits. I use the figures from this table in several projects, so here i'm just putting them all in one place that i can reference easily.
Luxeon 1 and 3 with no current (turn-off-point):
white/blue/green/cyan: 2.4V drop (= "LED forward voltage")
red/orange/amber: 1.8V drop
Luxeon-1 with 300mA current:
white/blue/green/cyan: 3.3V drop (= "LED forward voltage")
red/orange/amber: 2.7V drop
Luxeon-1 with 800mA current (over spec):
all colors: 3.8V drop
Luxeon-3 with 300mA current:
red/orange/amber: 2.5V drop
Luxeon-3 with 800mA current:
white/blue/green/cyan: 3.8V drop
red/orange/amber: 3.0V drop (note: my tests disagree with spec sheet)
Luxeon-3 with 1200mA current:
red/orange/amber: 3.3V drop (note: my tests disagree with spec sheet)
Typical values for regular "small" LED's with 20mA are:
red/orange/yellow: 2.0 V drop
green/cyan/blue/purple/white: 3.5V drop
Step 3: Direct Power!
Why not just connect your battery straight to the LED? It seems so simple! What's the problem? Can I ever do it?
The problem is reliability, consistency & robustness. As mentioned, the current through an LED is very sensitive to small changes in the voltage across the LED, and also to the ambient temperature of the LED, and also to the manufacturing variances of the LED. So when you just connect your LED to a battery you have little idea how much current is going through it. "but so what, it lit up, didn't it?". ok sure. depending on the battery, you might have way too much current (led gets very hot and burns out fast), or too little (led is dim). the other problem is that even if the led is just right when you first connect it, if you take it to a new environment which is hotter or colder, it will either get dim or too bright and burn out, because the led is very temperature sensitive. manufacturing variations can also cause variability.
So maybe you read all that, and you're thinking: "so what!". if so, plow ahead and connect right to the battery. for some applications it can be the way to go.
- Summary: only use this for hacks, don't expect it to be reliable or consistent, and expect to burn out some LED's along the way.
- One famous hack that puts this method to outstandingly good use is the LED Throwie.
Notes:
- if you are using a battery, this method will work best using *small* batteries, because a small battery acts like it has an internal resistor in it. this is one of the reasons the LED Throwie works so well.
- if you actually want to do this with a power-LED rather than a 3-cent LED, choose your battery voltage so that the LED will not be at full power. this is the other reason the LED Throwie works so well.
Step 4: The humble resistor
This is by far the most widely used method to power LED's. Just connect a resistor in series with your LED(s).
pros:
- this is the simplest method that works reliably
- only has one part
- costs pennies (actually, less than a penny in quantity)
cons:
- not very efficient. you must tradeoff wasted power against consistent & reliable LED brightness. if you waste less power in the resistor, you get less consistent LED performance.
- must change resistor to change LED brightness
- if you change power supply or battery voltage significantly, you need to change the resistor again.
How to do it:
There are a lot of great web pages out there already explaining this method. Typically you want to figure out:
- what value of resistor to use
- how to connect your led's in series or parallel
There's two good "LED Calculators" I found that will let you just enter the specs on your LED's and power supply, and they will design the complete series/parallel circuit and resistors for you!
http://led.linear1.org/led.wiz
http://metku.net/index.html?sect=view&n=1&path=mods/ledcalc/index_eng
When using these web calculators, use the Power LED Data Handy Reference Chart for the current and voltage numbers the calculator asks you for.
if you are using the resistor method with power LED's, you'll quickly want to get a lot of cheap power resistors! here's some cheap ones from digikey: "Yageo SQP500JB" are a 5-watt resistor series.
Step 5: $witching regulators
Switching regulators, aka "DC-to-DC", "buck" or "boost" converters, are the fancy way to power an LED. they do it all, but they are pricey. what is it they "do" exactly? the switching regulator can either step-down ("buck") or step-up ("boost") the power supply input voltage to the exact voltage needed to power the LED's. unlike a resistor it constantly monitors the LED current and adapts to keep it constant. It does all this with 80-95% power efficiency, no matter how much the step-down or step-up is.
Pros:
- consistent LED performance for a wide range of LED's and power supply
- high efficiency, usually 80-90% for boost converters and 90-95% for buck converters
- can power LED's from both lower or higher voltage supplies (step-up or step-down)
- some units can adjust LED brightness
- packaged units designed for power-LED's are available & easy to use
Cons:
- complex and expensive: typically about $20 for a packaged unit.
- making your own requires several parts and electrical engineering skillz.
One off-the-shelf device designed specially for power-led's is the Buckpuck from LED Dynamics. I used one of these in my power-led headlamp project and was quite happy with it. these devices are available from most of the LED web stores.
Step 6: The new stuff!! Constant Current Source #1
lets get to the new stuff!
The first set of circuits are all small variations on a super-simple constant-current source.
Pros:
- consistent LED performance with any power supply and LED's
- costs about $1
- only 4 simple parts to connect
- efficiency can be over 90% (with proper LED and power supply selection)
- can handle LOTS of power, 20 Amps or more no problem.
- low "dropout" - the input voltage can be as little as 0.6 volts higher than the output voltage.
- super-wide operation range: between 3V and 60V input
Cons:
- must change a resistor to change LED brightness
- if poorly configured it may waste as much power as the resistor method
- you have to build it yourself (oh wait, that should be a 'pro').
- current limit changes a bit with ambient temperature (may also be a 'pro').
So to sum it up: this circuit works just as well as the step-down switching regulator, the only difference is that it doesn't guarantee 90% efficiency. on the plus side, it only costs $1.
Simplest version first:
"Low Cost Constant Current Source #1"
This circuit is featured in my simple power-led light project.
How does it work?
- Q2 (a power NFET) is used as a variable resistor. Q2 starts out turned on by R1.
- Q1 (a small NPN) is used as an over-current sensing switch, and R3 is the "sense resistor" or "set resistor" that triggers Q1 when too much current is flowing.
- The main current flow is through the LED's, through Q2, and through R3. When too much current flows through R3, Q1 will start to turn on, which starts turning off Q2. Turning off Q2 reduces the current through the LED's and R3. So we've created a "feedback loop", which continuously monitors the LED current and keeps it exactly at the set point at all times. transistors are clever, huh!
- R1 has high resistance, so that when Q1 starts turning on, it easily overpowers R1.
- The result is that Q2 acts like a resistor, and its resistance is always perfectly set to keep the LED current correct. Any excess power is burned in Q2. Thus for maximum efficiency, we want to configure our LED string so that it is close to the power supply voltage. It will work fine if we don't do this, we'll just waste power. this is really the only downside of this circuit compared to a step-down switching regulator!
setting the current!
the value of R3 determines the set current.
Calculations:
- LED current is approximately equal to: 0.5 / R3
- R3 power: the power dissipated by the resistor is approximately: 0.25 / R3. choose a resistor value at least 2x the power calculated so the resistor does not get burning hot.
so for 700mA LED current:
R3 = 0.5 / 0.7 = 0.71 ohms. closest standard resistor is 0.75 ohms.
R3 power = 0.25 / 0.71 = 0.35 watts. we'll need at least a 1/2 watt rated resistor.
Parts used:
R1: small (1/4 watt) approximately 100k-ohm resistor (such as: Yageo CFR-25JB series)
R3: large (1 watt+) current set resistor. (a good 2-watt choice is: Panasonic ERX-2SJR series)
Q2: large (TO-220 package) N-channel logic-level FET (such as: Fairchild FQP50N06L)
Q1: small (TO-92 package) NPN transistor (such as: Fairchild 2N5088BU)
Maximum limits:
the only real limit to the current source circuit is imposed by NFET Q2. Q2 limits the circuit in two ways:
1) power dissipation. Q2 acts as a variable resistor, stepping down the voltage from the power supply to match the need of the LED's. so Q2 will need a heatsink if there is a high LED current or if the power source voltage is a lot higher than the LED string voltage. (Q2 power = dropped volts * LED current). Q2 can only handle 2/3 watt before you need some kind of heatsink. with a large heatsink, this circuit can handle a LOT of power & current - probably 50 watts and 20 amps with this exact transistor, but you can just put multiple transistors in parallel for more power.
2) voltage. the "G" pin on Q2 is only rated for 20V, and with this simplest circuit that will limit the input voltage to 20V (lets say 18V to be safe). if you use a different NFET, make sure to check the "Vgs" rating.
thermal sensitivity:
the current set-point is somewhat sensitive to temperature. this is because Q1 is the trigger, and Q1 is thermally sensitive. the part nuber i specified above is one of the least thermally sensitive NPN's i could find. even so, expect perhaps a 30% reduction in current set point as you go from -20C to +100C. that may be a desired effect, it could save your Q2 or LED's from overheating.
Step 7: Constant current source tweaks: #2 and #3
these slight modifications on circuit #1 address the voltage limitation of the first circuit. we need to keep the NFET Gate (G pin) below 20V if we want to use a power source greater than 20V. it turns out we also want to do this so we can interface this circuit with a microcontroller or computer.
in circuit #2, i added R2, while in #3 i replaced R2 with Z1, a zener diode.
circuit #3 is the best one, but i included #2 since it's a quick hack if you don't have the right value of zener diode.
we want to set the G-pin voltage to about 5 volts - use a 4.7 or 5.1 volt zener diode (such as: 1N4732A or 1N4733A) - any lower and Q2 won't be able to turn all the way on, any higher and it won't work with most microcontrollers. if your input voltage is below 10V, switch R1 for a 22k-ohm resistor, the zener diode doesn't work unless there is 10uA going through it.
after this modification, the circuit will handle 60V with the parts listed, and you can find a higher-voltage Q2 easily if needed.
Step 8: A little micro makes all the difference
Now what? connect to a micro-controller, PWM or a computer!
now you've got a fully digital controlled high-power LED light.
the micro-controller's output pins are only rated for 5.5V usually, that's why the zener diode is important.
if your micro-controller is 3.3V or less, you need to use circuit #4, and set your micro-controller's output pin to be "open collector" - which allows the micro to pull down the pin, but lets the R1 resistor pull it up to 5V which is needed to fully turn on Q2.
if your micro is 5V, then you can use the simpler circuit #5, doing away with Z1, and set the micro's output pin to be normal pull-up/pull-down mode - the 5V micro can turn on Q2 just fine by itself.
now that you've got a PWM or micro connected, how do you make a digital light control? to change the brightness of your light, you "PWM" it: you blink it on and off rapidly (200 Hz is a good speed), and change the ratio of on-time to off-time.
this can be done with just a few lines of code in a micro-controller. to do it using just a '555' chip, try this circuit. to use that circuit get rid of M1, D3 and R2, and their Q1 is our Q2.
Step 9: Another dimming method
ok, so maybe you don't want to use a microcontroller? here's another simple modification on "circuit #1"
the simplest way to dim the LED's is to change the current set-point. so we'll change R3!
shown below, i added R4 an a switch in parallel with R3. so with the switch open, the current is set by R3, with the switch closed, the current is set by the new value of R3 in parallel with R4 - more current. so now we've got "high power" and "low power" - perfect for a flashlight.
perhaps you'd like to put a variable-resistor dial for R3? unfortunately, they don't make them in such a low resistance value, so we need something a bit more complicated to do that.
(see circuit #1 for how to choose the component values)
Step 10: The analog adjustable driver
This circuit lets you have an adjustable-brightness, but without using a microcontroller. It's fully analog! it costs a little more - about $2 or $2.50 total - i hope you won't mind.
The main difference is that the NFET is replaced with a voltage regulator. the voltage regulator steps-down the input voltage much like the NFET did, but it is designed so that its output voltage is set by the ratio between two resistors (R2+R4, and R1).
The current-limit circuit works the same way as before, in this case it reduces the resistance across R2, lowering the output of the voltage regulator.
This circuit lets you set the voltage on the LED's to any value using a dial or slider, but it also limits the LED current as before so you can't turn the dial past the safe point.
I used this circuit in my RGB Color Controlled Room/Spot lighting project.
please see the above project for part numbers and resistor value selection.
this circuit can operate with an input voltage from 5V to 28V, and up to 5 amps current (with a heatsink on the regulator)
Step 11: An *even simpler* current source
ok, so it turns out there's an even simpler way to make a constant-current source. the reason i didn't put it first is that it has at least one significant drawback too.
This one doesn't use an NFET or NPN transistor, it just has a single Voltage Regulator.
Compared to the previous "simple current source" using two transistors, this circuit has:
- even fewer parts.
- much higher "dropout" of 2.4V, which will significantly reduce efficiency when powering only 1 LED. if you're powering a string of 5 LED's, perhaps not such a big deal.
- no change in current set-point when temperature changes
- less current capacity (5 amps - still enough for a lot of LED's)
how to use it:
resistor R3 sets the current. the formula is: LED current in amps = 1.25 / R3
so for a current of 550mA, set R3 to 2.2 ohms
you'll need a power resistor usually, R3 power in watts = 1.56 / R3
this circuit also has the drawback that the only way to use it with a micro-controller or PWM is to turn the entire thing on and off with a power FET.
and the only way to change the LED brightness is to change R3, so refer to the earlier schematic for "circuit #5" which shows adding a low/high power switch in.
regulator pinout:
ADJ = pin 1
OUT = pin 2
IN = pin 3
parts:
regulator: either LD1585CV or LM1084IT-ADJ
capacitor: 10u to 100u capacitor, 6.3 volt or greater (such as: Panasonic ECA-1VHG470)
resistor: a 2-watt resistor minimum (such as: Panasonic ERX-2J series)
you can build this with pretty much any linear voltage regulator, the two listed have a good general performance and price. the classic "LM317" is cheap, but the dropout is even higher - 3.5 volts total in this mode. there are now a lot of surface mount regulators with ultra-low dropouts for low current use, if you need to power 1 LED from a battery these can be worth looking into.
Step 12: Haha! there's an even easier way!
I'm embarrassed to say i did not think of this method myself, i learned of it when i disassembled a flashlight that had a high brightnesss LED inside it.
Put a PTC resistor (aka a "PTC resettable fuse") in series with your LED.  wow.  doesn't get easier than that.
ok.  Although simple, this method has some drawbacks:
- Your driving voltage can only be slightly higher than the LED "on" voltage.  This is because PTC fuses are not designed for getting rid of a lot of heat so you need to keep the dropped voltage across the PTC fairly low.  you can glue your ptc to a metal plate to help a bit.
- You won't be able to drive your LED at its maximum power.  PTC fuses do not have a very accurate "trip" current.  Typically they vary by a factor of 2 from the rated trip point.  So, if you have a LED that needs 500mA, and you get a PTC rated at 500mA, you will end up with anywhere from 500mA to 1000mA - not safe for the LED.  The only safe choice of PTC is a bit under-rated.  Get the 250mA PTC, then your worst case is 500mA which the LED can handle.
Example:
For a single LED rated about 3.4V and 500mA.  Connect in series with a PTC rated about 250 mA.  Driving voltage should be about 4.0V.
1-40 of 396Next »
Derek Lewis says: May 10, 2013. 1:42 PM
Hi Dan,
Loving this design! It's working really well for me so far, but I'm curious about component selection.
I'm using a (purchased) high powered buck regulator to get the voltage down to as low as I can, and still have this circuit operate. (~0.6V above the LED Vfwd) I'm building 36 of these circuits, to individually power and PWM twelve RGB LEDs (with 3 of the buck regulators, one for each colour), at 700ma per channel, so these serve as excellent low part-count CCRs. However, I'm not sure how various characteristics of Q1 and Q2 relate to the efficiency of the design. At 700ma x 36 any efficiency gains I can get by choosing the correct components will help reduce the amount of heat I have to deal with.
What kind of things should one look for in Q1 and Q2 to help with efficiency, either to allow input and output voltages to be closer, or anything else?
chriscrumpacker says: Apr 19, 2013. 12:00 PM
Dan, This post was a great starting off point and took care of a few questions I had been trying to work out. So thanks for the inspiration and great info. I just finished my Bike light and will be working on getting a full instructable up shortly. Here is my blog post, http://crumpspot.blogspot.com/2013/04/power-led-bike-tail-light-with-arduino.html And this is the schematic: https://www.circuitlab.com/circuit/b6r5h8/rear-bike-light/
petebarchetta says: Apr 5, 2013. 8:42 AM
hello Dan,
I'm looking at a similar project to drive 3 MCE cree LED's via a LM317 and 555 giving the PWM option for a bike light
can you advise what sort of circuit schematic and values I'd be looking at? I remember seeing a PWM circuit diagram you had on the instructible, but couldnt find it
janly says: Mar 12, 2013. 6:07 AM
Hi Dan,
I want to build this project http://blog.makezine.com/2012/01/02/luminch-one-offers-lumens-by-the-inch/ using RGB high power LEDS, forward current of 350mA. I will be using the Arduino Uno and I want to supply a constant current to the LEDS. Can this be done using LM317, if so how can I do it?
krytcz says: Jan 30, 2013. 7:26 AM
Hi Dan,
I have built the circuit #5. I am using a microcontroller to control the switching on and off of the LED. However, i have a problem. The LED does not turn off immediately when the signal at the Gate terminal is terminated. It takes quite sometime for it to turn off...With this, i am not able to dim the LED..Could you help me?
IansMusical says: Jan 14, 2013. 12:11 AM
Hello, Can anyone tell me if the Rds(on) value is important and what range it should be within if selecting a new mosfet? Also are there any none logic level mosfets that can be used, even if driving/using PWM from a 5v PIC micro? Thank you in advance, Ian
nathan.019 says: Dec 6, 2012. 6:14 PM
Hi! I need to design a LED driver which can power 70 typical (20mA) LEDs. i need to design it in a way that it will light up when a signal sends to turn it on. is it possible?? please help me..
jonesakysiu says: Nov 29, 2012. 10:18 AM
I'm planning to blink IR LED at 36kHz with microcontroller, and I'm thinking about using Your circuit from step 8 (http://cdn.instructables.com/FHY/YUTR/RCQEWP86JFY/FHYYUTRRCQEWP86JFY.LARGE.jpg).
But as far as I understood from the text, it limits current by "turning on and off" Q2 and LEDs. So the question is will it interfere with my PWMing rate? I need to have exactly 36kHz and if transistor will also turn LED back and forth it may cause problems...?
snotty says: Nov 19, 2012. 2:49 PM
Yeah! I made a couple of helmets like this. One with a 555 running bright red flashers. And one with a thin film solar charger built in.
Solar powered version:
Davidko says: Oct 11, 2012. 7:04 PM
Love the instructable but would love to ask anyone out there if they can help me out. I made curcuit #5 work perfectly and i am using an Arduino uno to work the pwm. my problem is when i try controlling more then one driver it doesnt "drain" both drivers. (one dims and the other blinks high/low like it is unable to pull the transistor down) how do i build a curcuit that willl be able to control 30 drivers with only one pin on the uno?
diy_bloke in reply to DavidkoNov 2, 2012. 4:06 AM
1 pin si gonan be a bit difficult because one pin just can only send one piece of info at the same time, so you would need a seriaol protocol, but then also you need the AC circuit to understand a serial protocol. I dont think it is really possible in practice
diy_bloke in reply to diy_blokeNov 11, 2012. 6:43 AM
Just in case I was dimwitted. Do you actually mean you wanted to drive 30 with one pin in total or 30 with each their own pin? Both impossible on the uno. You could add one or more multiplexers that you drive with a minimum amount of pins
Davidko in reply to diy_blokeNov 13, 2012. 7:06 PM
i would like to drive 30 drivers with one pin on the uno. i was thinking (if it is possible), using one pin on the uno to drive a transistor or MOSFET to turn ON an external 5-9v that would in turn, drive all 30 drivers in the circuit. That is possible, BUT when the main circuit is OFF how do i "Drain" all of the circuits so that the power drivers turn off? and how who the main circuit be hooked up?
i know a little about transistors, maybe could use a NPN for turning on the power and PNP for turning off and draining? i really dont know..
My knowledge is limited, but i wish to learn.
diy_bloke in reply to DavidkoNov 15, 2012. 3:07 AM
David, I recently replied already in a private message
I do not really understand your worries why wld you need to drain anything
diy_bloke in reply to DavidkoNov 14, 2012. 12:49 AM
Currently i cant see thereply i thought I send to you, so i just try again You do not need 30 drivers as you can feed a couple of LED's in series.
Wether you can connect the amount of drivers to 1 pin depends on a few things:
Please tell me the following:
what is your value of R1?
What current do your LED's draw?
Do you just want to switch them on and off or do you actually send a PWM signal to the LED's?
If your circuit is now working perfectly, it would seem the easiest to either increase the voltage so you can feed more LED's in series or drive 2 led's in series, so you need 15 drivers and then drive those via 15 diodes connected to the UNO
However, there are two concerns: will the voltage drop over the diode affect opening the FET (but you can try this with one diode), and will the 15 drivers not draw too much current from yr UNO (that is why I was asking about R1)
diy_bloke in reply to DavidkoNov 13, 2012. 11:54 PM
ok so you want to switch on 30KED's at the same time with one pin right?, that in fact is not so difficult. If you are using 9 volts you do not need 30 drivers as you can drive several LED's in series albeit not 30 on that Voltage. If you use a mosfet to turn on an external 5-9 Volts, That same mosfet can turn them off, no need for extra circuitry there.
How much current do your LED's draw. Are they just regular LED's? or power LED's
Davidko in reply to diy_blokeNov 14, 2012. 3:13 PM
i sent you a private msg a little while back stating the conditions and what i was thinking of doing. but here it is again
i would like power around 50-100 high powered LED's...
i have and would like to use:
12vdc 10A power supply (maybe 24vdc and just hookup more LED's in series to makeup the difference and use less drivers in the future)
IRF540N 33A/ 100V/ 0.040 Ohm/ N-Channel Power MOSFET with heatsinks
2N3904 transistor
0R75 ohm 2w resistor
100K ohm resistor 1/4W (i could use different values if specified)
3x 3w epistar white 3.2-3.8v 700mA LED (per built driver) and i can adjust the voltage on dc power supply(11vdc/3 = 3.66vdc each LED)
a fan for the breadboards
and an Arduino uno to control the PWM with one or two pins
now i would love to build this in a way that can PWM control these drivers with one or two pins on the Arduino. i starting building the driver in circuit #5 (and 3x 3w LED's) with great success but when i hooked up TWO drivers to one pin that is when driver #1 LED's would flicker and driver #2 LED's fade out and work like it was suposed to...(programmed the arduino to fade in and out slowly for testing purposes)
so that is when i needed help. i got to thinking.... i suppied circuit #5 with 12vdc to the LED's but i controlled the N-Channel Power MOSFET with my ARDUINO SO what if i suppied the MOSFET or transistor with 5-9vdc or 12vdc and made it supply ALL the drivers somehow. but if i do that, when the power is ON everything will work(i hope) and when the power is OFF, everything might flicker because there is no "DRAIN" hooked up to that circuit.(just like my experiment showed hooking up the drivers directly to the Arduino UNO) i dont know circuitry too well to accomplish this task so i needed some help.
any feedback would be greatly appreciated.
Thank you.
diy_bloke in reply to DavidkoNov 15, 2012. 3:12 AM
David
I replied to that message. didn't you get that reply?
Well there might be various reasons for the flickering
I asked about the value of R1 (the resistor connected to the Uno pin). It seems most likely that the two drivers are influencing eachother. diodes maight be the answer but I need to know the value of your resistor R1 is that the 100k Ohm you refer to?
diy_bloke in reply to diy_blokeNov 15, 2012. 3:45 AM
Just a bit more of a reply
Although theer might be different solutions to your problem (e.g. separating the circuits with diodes or transistors, your thinking of switching all the drivers on and off with another FET is good.
I do not really foresee the problems you mention (and are guessing about).
One of the problems you may have is that you are using an IRF540N FET. As I understand that is designed to work with about 10 Volts as a trigger and though it is odd there would be a difference in how the two circuits you built react, it is well possible that one of the circuit sjust does not get enough trigger voltage from the Arduino.
Nevertheless, driving all the drivers as a load by another MOSFET should be possible (then ofcourse you would need to change yr circuit accoring to say #2 or 3#)
Nevertheless, you may try something else:
Change your circuit into circuit #2 or #3 (does not matter which one) and put a transistor in parallel with R2 or Z1 and add a 10 k in its baseline. Drive that 10 k with your uno. That should work. (although it will invert the signal: high = off, Low=on)
As I am not building this myself it is a bit of trial and error, but subsequently you could go two or 3 ways. The easiest would be to give each of your drivers their own transistor and connect these all to one Arduino pin (make sure you do not draw more than I think 40 mA) or you could hook up all the circuits to one transistor (but I'd suggest you would use separation diodes then).
I suggest you adapt the two circuits you built in the way i describe and see if you can drive both of them with one pin
diy_bloke in reply to diy_blokeNov 15, 2012. 5:09 AM
I might have found something for you, akin to what i describe
Davidko in reply to diy_blokeNov 20, 2012. 3:12 PM
diy_bloke, you are the BEST! i do not know how to thank you enough. with the circuit that you have provided me, i have made 2 drivers to work from ONE Arduino uno pin using PWM EXACTLY the way i wanted. I really cant thank you enough good sir. now i am on my way to constructing about a dozen of these circuits. Thank you!
diy_bloke in reply to DavidkoNov 21, 2012. 8:43 AM
David,
I am glad I could have been of help. It took a while before I exactly understood what you wanted, but I am happy you got what you wanted. I hope it all will still be fine with a dozen of them, you may need to trim the value of R3 perhaps.
Go dluck and if you need more help don't hesitate to ask
Davidko in reply to diy_blokeNov 15, 2012. 6:28 PM
That looks amazing. You are the best. I thank you for helping me and I will definitely try making that circuit tomorrow as it is way too late today to even start. (when I get started I can't stop till its done) I really appreciate your patience and knowledgeable responses. I will write back as soon as I build the circuit you described. Thank you again and I will keep you posted.
diy_bloke in reply to DavidkoNov 15, 2012. 11:44 PM
My pleasure. We all have to learn
dreadnaught says: Nov 11, 2012. 9:38 AM
Hey can we run this in series with other circuts?
josephx86 says: Sep 3, 2012. 12:10 PM
Hi
I want to build a constant current source which has input voltage between 3-311v.
how can i make it with low cost and transistor based circuit?
Thank you very much.
diy_bloke in reply to josephx86Nov 1, 2012. 3:37 AM
you could use a 3055 or comparable powertransistor, as in attached picture. the LED curent is roughly 0.6/R2. 3 Volts input voltage might be pushing it a bit but should be doable
charles eletro 2012 in reply to diy_blokeNov 11, 2012. 5:42 AM
earned guy I was in need of such a scheme
diy_bloke in reply to charles eletro 2012Nov 11, 2012. 6:07 AM
happy i could be of help :-)
josephx86 in reply to josephx86Sep 3, 2012. 12:16 PM
Oh, I forgot write i want to drive 1 up to 80 3.2v / 20ma white LED with 311vdc.
diy_bloke in reply to josephx86Nov 11, 2012. 6:28 AM
joseph
that is kind off a stretch. Do i understand correctly that you want 1 circuit that can drive 1 LED with 311 Volt as well as 80 LED's with 311 Volt?
if the LED is 3,2 Volt you would need a transistor that can take at least 310 Volt as Vce or as much as (311-80x3.2)=55 Volt when you use 80 LED's.
Going by the circuit I just uploaded before (but you are going to need a different transistor) you would need an emmitter resistor of about 30 Ohms (1/4 Watt more than enough). But I would not know a transistor that can take 310 Volts just from the top of my head. Even the BU111 can only take 300 Volt, but even then, that would be overdoing it as it can take 6 amps and u only need 20MA.
The MJ16110 can take 400 Volts, but at 15 amps and tht is looking launching a scud missile to kill an ant. I am really not aware of a 350 Volt 50-100mA low power transistor.
If beforehand you would already know that you will drive 80 LED's then it becomes a whole different ballparc because then a BC546 would be enough.
I am not saying you should do things different from what you plan but as far as I understand your plans you are setting yourself up for trouble and high cost, whereas it could be simple and cheap.
Also, are you really bound to 311 Volt? because even with 80 LED's you still will be turning 55 Volt*20mA=1 Watt into heat.
Perhaps your project will still be possible if you rethink a bit what you are doing
diy_bloke says: Nov 1, 2012. 4:12 AM
Though circuits 1-2 will most likely work with almost any power NFET, for the circuits 3, 4 and 5 it is pretty important that indeed a 'Logic' type NFET (usually with an 'L' behind the typenumber) is used because 5 Volts may not be sufficient to completely open up non-logic level NFET completely. Now ofcourse this won't alwaysbe necessary, but if drawing higher currents it might well be.
One may want to consider taking circuit 4 and replacing the zener with a transistor that has its base pulled low via 1 M resistor and that receives its PWM signal via a (say 4k7) base resistor
bloftin says: Oct 26, 2012. 10:55 AM
Thanks for a great instructable. Since high power LEDs are not that cheap, some good advice from Winder's book "Power Suppliews for LED Driving" is to use a zener diode (1N5334B) in place of the LEDs until you have tested your circuit. Example is to have one like this for each 1w LED in circuit.
http://www.mouser.com/Search/ProductDetail.aspx?R=1N5334BRLGvirtualkey58410000virtualkey863-1N5334BRLG
skylerdprahl says: Oct 4, 2012. 2:20 PM
You have helped me more than you will ever know. This circuit is amazing if your Vf on your led's is close to your input voltage. It then becomes super efficient.
I bought a bunch of MC34167's hoping to run some led's with it, only to find that it doesn't have current sensing. So you saved my reer.
To make sure of the Forward voltage drop being close to your input voltage though, the MC34167 is a tremendous choice. It is a single chip step up/down converter with a minimum of external components available that will get you to the correct voltage for super cheap and not have to worry about heat as it is crazy efficient.. I now use this along with most of your circuit for current control for 4ampere's worth of 100lumen/watt led's in an automotive environment....... CRAZY bright. And no heat given off anywhere except for the LED's themself. Best of all, no need for an O-scope and you can get this much efficiency. Lets face it, if you have a $4000 scope you can make your own PWM circuits and not have to worry about any of this. But if you don't it is good to know there is still ways to do things.
electricmic says: Oct 3, 2012. 12:41 PM
Great tutorial!
When calculating the wattage of resistors in version 1, it would be of great educational value to demonstrate the calculation using the Power=I*I*R formula
Davidko says: Sep 22, 2012. 10:55 AM
Excellent Instructable, i would just like to add and you might want to inform people that if this is done on a solderless breadboard with inproperly connected wires the curcuit will not work properly. i was getting strange reads of 400-500mA. when i soldered the parts together, perfect 690mA. As well the draw may vary depending on the voltage. Very imformative instructable.
Great job.
vallka says: Aug 31, 2012. 5:00 PM
Hi, I would like to run 3 Cree Cree XLamp XR-E Q5 off of a 14.8-18.5 li-ion battery, will this driver work to run them all or one driver for each?
This will be for a mtn bike light so the heat sink will get plenty of air flow.
timelessbeing says: Jul 3, 2012. 12:58 AM
I only have a p-channel FET (U9024N). How do I modify this circuit to work with it?
timelessbeing in reply to timelessbeingJul 4, 2012. 1:15 AM
Here's an attempt I did with Circuit Simulator:
biglongurl
Unfortunately, the current doesn't seem too stable. :(
chikoroll says: May 27, 2010. 6:36 AM
hey mate, i want to hook up a 25watt LED to my car
the voltage is 13-14v
my battery runs 12v (car off) and 13.6v (alternator charging)
would this be acceptable to run direct from battery, or should i run a dc-dc converter
the link is what i'm looking at
http://cgi.ebay.com.au/5-PC-BRIGHTEST-25W-WATT-HIGH-POWER-WHITE-LED-1400-Lumen-/390118430163?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item5ad4ded5d3
1-40 of 396Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
