3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High Power LED Driver Circuits
Step 2Power LED performance data - handy reference chart
Below are some basic parameters of the Luxeon LED's which you will use for many circuits. I use the figures from this table in several projects, so here i'm just putting them all in one place that i can reference easily.
Luxeon 1 and 3 with no current (turn-off-point):
white/blue/green/cyan: 2.4V drop (= "LED forward voltage")
red/orange/amber: 1.8V drop
Luxeon-1 with 300mA current:
white/blue/green/cyan: 3.3V drop (= "LED forward voltage")
red/orange/amber: 2.7V drop
Luxeon-1 with 800mA current (over spec):
all colors: 3.8V drop
Luxeon-3 with 300mA current:
red/orange/amber: 2.5V drop
Luxeon-3 with 800mA current:
white/blue/green/cyan: 3.8V drop
red/orange/amber: 3.0V drop (note: my tests disagree with spec sheet)
Luxeon-3 with 1200mA current:
red/orange/amber: 3.3V drop (note: my tests disagree with spec sheet)
Typical values for regular "small" LED's with 20mA are:
red/orange/yellow: 2.0 V drop
green/cyan/blue/purple/white: 3.5V drop
2 comments
Feb 2, 2008. 12:48 PMdoctek says:
How did you make these measurements? One way I can think of is to put appropriate current limiting resistors in series with a led and measure the voltage drop across the led. Is that indeed what you did or is there a much cleverer method I'm missing?
Jan 17, 2010. 5:24 PMNyxius says:
LED are incapable of limiting current on it's own.  Therefore, voltage drop across the LED is dependent on total potential and total load in series with the LED.  Too much potential and not enough load means that the voltage drop across the LED will be high enough to "fry" the LED.  This is because LED have very small impedance compared to regular light bulbs. The voltages listed on the spec sheet are recommended drops that will ensure long lasting lifetime.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
524
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
