Step 5$witching regulators
Pros:
- consistent LED performance for a wide range of LED's and power supply
- high efficiency, usually 80-90% for boost converters and 90-95% for buck converters
- can power LED's from both lower or higher voltage supplies (step-up or step-down)
- some units can adjust LED brightness
- packaged units designed for power-LED's are available & easy to use
Cons:
- complex and expensive: typically about $20 for a packaged unit.
- making your own requires several parts and electrical engineering skillz.
One off-the-shelf device designed specially for power-led's is the Buckpuck from LED Dynamics. I used one of these in my power-led headlamp project and was quite happy with it. these devices are available from most of the LED web stores.
As for the cons, today they are much less than $20 for the current regulating type, see websites like http://www.kaidomain.com or http://www.dealextreme.com
Frankly at their low prices (typically between $1.50 to $5 per board delivered) it makes little sense to do anything else but buy the regulator boards from them. Only major issue is the most economical regulator boards are designed for flashlights so if the application needs board isolation you have to devise a method (like epoxy to attach to a mounting frame, and to solder on the supply leads where the battery and flashlight body contacts are). I have used several of these and they work very well for the price. I see no reason to spend $20 on a buckpuck, it's highway robbery these days opposed to the past when shoppers were more limited in what was available.
They aren't just for Cree LEDs, they are current sensing based on their individual specs so they regulate to that spec'd current level. Why would you use 30+ less efficient LEDs? Are you sure they are 100mA? The small 5mm encapsulated type are generally 100mW, which is 20mA conservatively or about 30mA with good heatsinking of the leads to the PCB copper.
You have to do some math to determine the logical arrangement as well as consider the input voltage. You give none of these so it would be excessively long postings to cover every scenario. I will give basics instead.
1) Determine your input voltage, keeping in mind the max the regulator can handle (same with any regulator actually).
2) Determine the voltage drop of the regulator. For example if your input is 8V and the regulator drops 1V, you have 7V out maxium.
3) Determine forward voltage of the LEDs. Suppose it's 3.4V @ 300mA. You can do the math to see 7V=n*3.4V, n=2.06
4) Rounded down 2.06 is two, you could put two of the example LEDs in series. That means you would have 15 parallel series of 2 LED to arrive at 30 total LEDs, except you claim 30 LEDs at 100mA each which is 3 amps. This is one area where I wonder if you have 20-30mA LED, or if buying some new why you would buy less efficient 100mA LED instead of 350, 700mA or more LEDs. Since the regulators linked were about 1A, with 100mA LEDs you'd need three boards and splitting up the LEDs, 15/3 = 5 parallel series of 2 LED per board.
5) LEDs don't have exactly the same forward voltage as spec'd, it varies a little so with your 2 x 3.4V series you have 6.8V forward from 7V and 100mA drive current so (7-6.8)/R = 100mA.
6) R = 0.2V/0.1A, you'd put a 2 Ohm resistor in series with each series of 2 LEDs, so you'd need 15, 2 Ohm resistors to make it work in this example.
In summary, yes there are many ways to configure LED arrays you just have to do the math to see how you need to go to get from where you are starting to where you need to be. With some combinations and input voltage options the flashlight regulators may not be ideal, if your Resistor value goes too high it becomes more lossy, but on the other hand a cheap way to lose some current through a handful of resistors may not be a problem if the power source is not a low capacity battery.
Doctek I think where's your stuck is on the basics of combining LEDs in series and parallel combinations and calculating out the parameters. Beyond examples you need to be more clear about defining the project requirements whether they be max brightness, minimal size, max efficiency, minimal cost, max resistance to extremes of temperature, max lifespan, max battery life or some combination of these. Once you have clearly defined your goal then choosing parts and adding complimentary circuits to reach the goal will become a more clear process.
I suggest looking at some of the LED calculators found via Google search and doing some more basic circuits before trying to tackle something more advanced, costly and time consuming.
