loading
Step 2: Bend Cardboard to Curves
Cut rectangular pieces.
The height of each piece will determine the depth of your box.
Bend over a tube shape or edge of a table to create a neat curve.
<p>I'm almost finished with mine, just need to neaten up some of the painting...Thanks 50Theo, I copied your design, which worked really well :)</p><p>Thanks so much for this instructable - this shelf is the perfect thing to complete my room. The colours match my decor - a mural, ad three paintings, in blue, green and pink. </p><p>A few tips for anyone doing this project:</p><p>I just used PVA glue to stick the shelves down, and then papier mache to make it stronger, seems to work fine</p><p>I painted just the back of the shelves, not the walls; in hindsight, doing this is easier before you stick the shelves down, because then you don't get paint everywhere, which means you don't have to paint white paint over the walls again. In other words, plannign really helps, so you can do the hard bits first</p>
<p>Wow Great job!</p>
Thank you !!!
Can I use masking tape instead of gummed tape or is there any other substitute to gummed tape
Yes, you noticed how impossible masking tape is to remove off postage packs or cardboard boxes, that would make it a really sturdy join. Also the masking tape I would use is the brown lightweight, plasticky type rather than the yellow papery type sometimes comes off.
do I really need the gummed tape and can I just make a larger version and glue it inside a box
so I love this and it's starting to get a lot of attention over on Pinterest btw... http://pinterest.com/pin/114138171775809438/<br><br>I am confused by your images and content. You say it's a small version of what the big one looks like.... the brown and very nice looking finished one looks like a large wall version with shelves that will at least hold cd size items/books. <br><br>Is that the full version finished?? I can't tell. THe video only seems to finish up the blue version which looks quite rough.<br><br>Would love to make this... just wanted to know how you got such a beautiful finish on the brown larger (I am assuming) version. <br><br>Thanks! New to this site, finally signed up. - Molly
hi! the unpainted full sized shelf is by Elsa Paige. My blue version looks pretty rustic because I covered it with unusual watercolour tape, (as I wanted to quickly make this instructable). <br><br>It is quite small, around 60cm wide and can fit light items. Hence shadowbox!<br><br>To have a neater finish I would do the edges properly with another type of watercolour tape.<br><br>If you wanted to make the larger one for books the link above shows another French Artist who uses 3 lots of 3 ply cardboard for an ultra strong cupboard. Everything is support by the strong glue you need to attach shelves and surrounding cardboard to the BACKING. good luck!
Hi, first I have to say that I absolutely love the bookshelf. It is a splendid take on an a mundane piece of furniture. Love It!<br><br>I was just wondering, what deviations/alterations you made in the preparation of the bookshelf vs the mini-shadow box?
Thanks! <br> <br>the difference between the mushroom bookshelf and the circular one is the central curve which greatly supports the whole structure. <br> <br> I think its a lot stronger than the mushroom one. <br> <br>I tried to add lots of layers to make it stronger. This is the replacement for Eric Guiomar struts technique. <br> <br>Otherwise, I think that circular shapes tend to be stronger than straight edged boxy types.
About This Instructable
101,865views
110favorites
License:
More by Scriptone:How to Make a Abacus from Cardboard Steamed Gluten-Free Pizza (Crispy Bagel-kind of crust) Slideshow: Cardboard Mushroom Bookshelf (Hot-glue Method)
Add instructable to:
