Introduction: Circular Saw CrossCut Jig
This home made circular saw crosscut jig will add a precision cutting tool to your workshop at little cost. Hopefully my instructions are clear and easy to follow.
Step 1: Getting Started
MATERIALS
- Screws
- Tape
- Wood Glue
- Scrap Wood
TOOLS
- Circular Saw
- Drill
- Combination Square
- Clamps
Step 2: Cutting on Dimension
I already have a 100x30cm table that i used for the base. The other lumber are cutted 100cm for the side ones and 30cm the two front and back. I used this measurament because are well for my usage and are compatible with my circular saw, you'd make this based on your saw size and request. The result should be like the image above.
Step 3: Build and Assemble
I applied some tape for hold in square the pieces then i used glue and screw for fix it. You'd screw first one guide, then use the saw to make sure the second guide will be perfectly distanciated and parallel.
Step 4: Finishing
Apply some wax for smooth movement.
Step 5: Result
The cuts will be in square as much as squared the jig is. Mine are very close to 90 degrees angle so i'm happy whith this tools.
2 People Made This Project!
3 Comments
Hi Cactools,
I liked the idea very much, but tell me one thing, if the wood is thicker than the opening? I did the same thing, and then I realized I had to adjust. I did the following: I separated the chime, fastened two screws with threaded wings at each end to increase the opening and then fix it better. It was excellent. If I help you, we'll win the day! Good luck !
Great idea. I am going to need to make one of these for my workshop.
Thanks!
