In the photo you see my rip guide prepared to trim 1/8 inch from the bottom of a door.
Remove these ads by
Signing UpStep 1: Materials and tools
- 1 MDF trim board 3/4 x 3 1/2 x 96 inches
- Tempered Masonite 3/16 x 15+ x 96 inches
- Bevel-headed wood or sheet metal screws: # 8 x 3/4 inch
Tools
- Rule
- Drill with bit and countersink
- Screwdriver
- Sawhorses
Have the store rip 15 or 16 inches from the long side of a sheet of 4 x 8 feet Masonite. It does not matter if the cut is not completely straight, but the panel saw will likely yield a straight cut. (My saw's base is wider than some with almost exactly 5 inches between the edge of the base under the motor housing to the nearest side of the saw blade. If your saw's base is smaller, the Masonite could be narrower. But, the Masonite needs to be twice as wide as the base dimension on the motor side of the base plus the width of the trim board. Leave a little extra on both sides to be trimmed away.)
I had a car, not a truck, when I went to the store. I had the store cut the remainder of the Masonite so I had two pieces about 33 x 48 inches each. They may not go into a car trunk, but will slide through a rear car door and not rise above the seats to obstruct your rear view on the way home. (The panel saw at my store is poorly aligned and corners on crosscuts are not square. The operator has tried several times to get the management have the saw aligned again, but has been unsuccessful. Be aware.)
Plans for rip guides like this often suggest ripping about 6 or 8 inches from the long side of a sheet of 1/2 inch plywood. This is aligned along the edge of a sheet of Masonite. That means you may be buying both a sheet of plywood and a sheet of Masonite. One advantage to my version is that you buy a sheet of Masonite and a trim board only, which makes for a lower cost. (Also, if you are cutting the piece that will actually guide the saw, you will need a means of guaranteeing that cut is perfectly straight. That may not be possible in a beginner home workshop. The straight trim board will be a big advantage for getting a straight guide without a large table saw the beginner workshop may not have.)
Center the trim board on the long Masonite piece and clamp with "C" clamps. Support this sandwich with enough sawhorses to keep it from bowing.
Visit Our Store »
Go Pro Today »
Simple, fast, and cheap. I cut a lot of 1 1/2 styrofoam board (4x8 and 4x10 sheets) on the ground. A 2x4 under where the saw will run keeps the blade out of the dirt or grass and provides a rigid surface for the cut.
The saw guide dedpicted would be really useful in a cabinet shop but wouldn't last long in a construction site with the foremans whip on a workers back.
And I like your folding carpenter's rule, don't see these much any more.
Bill
Thank you for the comment. That carpenter's rule was purchased new in 1970. I have used it a lot. The numbers on inside surfaces are still mostly like new. Those on the outside have suffered. Once a friend taught me how to unfold these rules in one speedy and continuous motion. I thought YouTube would have a video, but I do not find one. I may need to demonstrate here it one day.
One of my strongest memories is when I helped my dad install an oil furnace at the family home in Indiana. 1951, I was 10. We were using his folding rule, which I tried to open in a speedy motion, and it broke in half. I was distraught, did not stick around to see my dad's reaction.
1) I find running the power cord up and over my shoulder does a nice job of keeping it out of the way and keeps it from snagging various things. If the wall with the plug is in front of you, use an extension cord long enough to loop it around behind you, then up over your shoulder.
2) In use, orient your clamps as pictured in steps 4, 5, and 6 (turning part down)as opposed to as show in step 3 (turning part up). Not only does that help prevent power cord issues, it also helps prevents the screw part from snagging clothing or poking you and surprising you while running a power tool (not good).
3) Long ago I realized cutting through the tops of my sawhorses wasn't a big deal (see a photo of them in my Treedle Lathe instructable). The biggest reason being that it supports both pieces after the cut. When they get worn out, I'll just build new ones. The ones I have are roughly 20 years old and I don't feel inclined to replace them yet.
4) Well done, I too wished I had known about such a guide many years ago. Without one, it is nearly impossible to cut a straight line. With one, a very simple operation. The only change I'd be inclined to make would be to glue the mdf trim board to the masonite. Screws may loosen or 'ream out' their holes with pressure and vibration over time.
I did not want to cut into my saw horses because one of the supports is a steel roller I did not want to cut with my carbide blade.
Thank you for your comments and suggestions.
I strongly considered four foot and eight foot versions, but decided to make the eight foot version and simply let the ends hang over both sides of shorter things like doors. I am not certain how many eight foot panels I will be ripping. Once we owned a big Mercury station wagon, and I could slide a whole 4 x 8 sheet of plywood into it with all doors and windows closed. Still, there have been times when I needed some very specific cuts from a sheet of plywood. Once I bought a nice sheet of oak veneer plywood at a specialty dealer. He let me plug in an extension cord in his parking lot and use my own circular saw to cut as I needed so the pieces would fit into the back seat of the '63 Chevrolet sedan we drove in those days.
Thanks for looking. I hope it serves you well.
And well done, and well depicted.
