Clammy Cardboard Costume by reuben14
Step 2: Part P1: The Bottom Shell, Continued
5. One inch from the edge of the larger circle, draw (T3) and cut out (T2) a 1.5'' by 1'' rectangle. The 1.5'' edge of this rectangle should be closer to the edge of the circle.
6. Across from that rectangle, cut (T2) a 9'' slit extending from the outer edge of the circle.
7. One-eighth of the circle from that slit on either side, cut (T2) two more identical slits.
8. One-eighth of the circle away from each of those slits, cut (T2) two more identical slits.
9. One-eighth of the circle away from each of those slits, cut (T2) two more identical slits. There should now be seven 9'' slits in the circle.
10. Pull each flap over the next flap clockwise. The circle should now curve inward, forming a dome.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
