The Clamping Squares
Introduction: The Clamping Squares
If I was a superhero, my weakness would be glueups. Thankfully, those aren't really needed in the crime fighting business ... yet.
Maybe I don't plan ahead. Maybe I'm too impatient and just desire instant gratification. Maybe I'm just not that good at woodworking. I'm not sure, but tons of people are really bad at driving and they just keep doing it.
I'm making some games for Holiday gifts and they all have mitered sides. I have a shop made clamping jig for picture frames, but it isn't good for taller sides like these. I tried a band clamp, but there was some sliding. I moved up to some pin nails, but there was still some racking. I want this thing as square as possible (I know it won't be 100% square because life taunts me).
To the scrap bin!!
Step 1: The Material
I have a bucket of corner cut offs ... left over from a project which required discs. The dics were cut from plywood squares, so these corners are already square. I also checked them to make sure.
Step 2: The Layout
I need holes large enough for my clamps and far away from each other to give room for afore mentioned clamps. For me, this was 3" from each squared corner and then 1 1/8" in from the edge to intersect that mark.
Step 3: The Hole Drilling
I made my holes 1 1/2" with a forstner bit.
Step 4: The Clamping
Put your square in the corner and add your clamps. The only thing left is to smack yourself in the head for not making a stack of these years ago (my head still hurts).
Step 5: Update: Cleanup and Modification
Using a temporary stop block on my miter saw, I trimmed the square side lengths to be even and then trimmed the front straight. All cosmetic.
Lastly, as suggested by a member of the community (good call dimtick), I nipped off the back corner to allow for any glue squeeze out, which would otherwise make these blocks part of your project. Non-Super Hero Teamwork!
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    I smacked myself in the head for not thinking of it myself.
    Simple thus brilliant.
    very nice probably one of the easiest made corner clamps ive seen.Nice work
    great idea.
    Well done! Such a simple and easy solution to a vexing problem. THANK YOU!!!
    Thank you for sharing your awesomeness!!!
    nice project. I've always just used a speed square but I only have a couple of those. I could see how having a stack would really come in handy.
    Funny you should mention that. I have one speed square, which I clamped in one corner. Then I have a broken combination square so I used that in the other corner. That was when the, "I'm an idiot" moment hit me and I made these.
    one thought: that it may be a good idea for you the knock off the inside corner or the triange. just enough so that if you get any glue squeeze out, the triangle wont get stuck to your piece.
    for frames I would also recommend using a strap clamp. it can be tricky to get all the miters perfectly aligned so use it in combination with the triangles.
    Good call on nipping off the corner.
    I have some Bessey band/strap clamps and they come with the corner things. Then I have a clamping jig I made for frames. You can also make a wedge style jig, which work well.
    A friend of mine swears by using his router table to make locking miters. he even likes the way they look when visible but my wifes, way to Martha Stewart for that :)
    my crappy craftsman router table is not up to doing lock miters so I haven't done them myself. topic....rambling......Great idea with the clamping triangles!!!
