Step 27Clasp on. Clap Off
Plug in the battery. Put the bra on as per normal using the electromagnetic clasp. When you are ready for it to come off, simply clap twice.
If you want to be "modest" about it, you can make your own LED Heart Pasties.
A super-special thanks to Danica Uskert for helping demonstrate the bra.
I've got one: Since the attachment point should be under a fair amount of tension before release, consider the mechanism used to release malfunctioning parachutes in emergency conditions. It's called a "3 Ring Release" and uses lever action to reduce the force necessary to release the mechanism.
http://en.wikipedia.org/wiki/3-ring_release_system
It also has possibilities for the trigger on a trebuchet.
I would suggest a small pager motor with a worm gear or a threaded tube on one side and a threaded shaft on the other side. Possibly more compact than the relay and it can not unclasp without spinning the motor. Regardless of how you facilitate it, lingere that flys off on command is just beyond amazing!
(and thank you Danica, you're an eye catcher)
When you release an item for consumer use you need test it thoroughly at what you believe will be the extreme conditions. If you plan on selling this at a premium, you may also want to consider life testing if your consumer believes that the product should last a long time given the price.
Can you tell I sew as a hobby but have a degree in mechanical engineering and worked in quality engineering for many years?
AV
