Introduction: Clap Switch (wall Switch Mountable)
Picture of Clap Switch (wall Switch Mountable)
are you tired trying to find a way to turn Off or turn on the light?
Would you want to be more innovative by clapping your hands like the ones in the movies?
or even access other tools with your clap
I have wondered if there would be a way to turn on or off the light by clapping since I watched a movie where in the actor just clapped and the light turned off or on. Making this project needs a lot of patience and open mindedness since a lot of problems will occur during the process. Good solder and PCB design will be very useful in this project.
This project will work by 2 IC, the 4017 and the 741, the 741 will compare the voltage to send a pulse to the 4017 which is set as a toggle. to control any appliance there is a relay.
Step 1: Materials Needed
Picture of Materials Needed
You will go into 2 stages the prototype and the Fixed version but they will both use the same components
Components:
  1. 4017 Decade counter
  2. 741 Op-amp
  3. Electret MIC  (long range)
  4. NPN transistor
  5. Relay (6v)
  6. 2 LED any color
  7. Diode (rectifier)
  8. Terminal Block
  9. Battery Clip (9 volts)
  10. 9 volts battery
  11. Resistor
  • 100 Ohm
  •  1k ohm
  •  300 ohm - x3
  •  22k ohm
  •  470 ohm
  •  10k ohm
  •  150 ohm
Tools:
  • Soldering Iron
  • Soldering Stand
  • Bread Board
  • Pliers
  • Cutter
  • Screw driver
  • Multi-tester
  • Power Source
  • PCB
  • Permanent Marker
Step 2: Testing the Circuit
Picture of Testing the Circuit
This Step is the crucial step because you need to test the circuit before placing this into a PCB. You would be wasting your time if you place the circuit straight to the PCB once there is a problem. This step is just to test if the Circuit is working and once you transfer it to the PCB you would know that the problem would be in the PCB
Step 3: After Breadboard Test (PCB Preparation)
Picture of After Breadboard Test (PCB Preparation)
If your circuit works in the breadboard make the PCB design.
  1. Cut it into size
  2. Draw the circuit boar design and then double check for shorted drawing.
  3. Etch the PCB in ferric Choride and watch the design come out
  4. Test the circuit using the ohmmeter (multi-tester)
  5. Drill the Necessary holes.
  • For better fitting of the components try to place them in their spot.
  • If you commit a mistake in drawing the design you can use a cutter to scrape the marker off
  • For your guide refer to the pictures
Step 4: Place in All Components and Solder Them
Picture of Place in All Components and Solder Them
After having the holes drilled just place all the components where it should be and solder them.
Be careful for wrong placement of some components like wrong reading of Resistor, Wrong placement of Diode and such more.
The Mic also has its polarity.
Step 5: Do the Final Testing and Trouble Shoot
Picture of Do the Final Testing and Trouble Shoot
You are done and here you will test if your product works
  1. Use a multi-tester and check for shorted connection.
  2. if there is no shorted connection use a 9v battery and test.
Troubleshooting:
  • Usual problems is due to the mic sensitivity and the mic. I suggest using a mic from a Used webcam or a mic used in a comp where in it hears in long distance
  • battery source may be the source of the problem as well since the 741 just compares the voltage that passes thru and  may change its sensitivity.
Project mounting
  • This project can be used in lamps or even inside the wall switch
The creator sid (author)2017-02-02
it would be great, if you send me your clear schematic.Your schematic is a bit rough...
You can send me the schematic her:
siddhantsinha070@gmail.com
majua1 (author)2015-01-03
thanks for u r concern... actually am looking for how can i operate clap switch in 220v some one told me use Relay ... any idea abot that.. tried this but... no output... anything else u have
majua1 (author)2014-12-05
could u please help me out ...to create like this project i surfed a lot ... please send me clear circuit diagram with picture using breadboard
Thank you..
Thank you..
meghavi ved (author)2014-02-23
can u pls send me perfect & clear circuit diagram..???
email id is : meghavived@gmail.com
"Thank u"
vill.mendez (author)meghavi ved2014-10-08
i was breaking my head trying to find the correct way to conect the elements but i found the diagram here you are
http://niotronic.blogspot.mx/2013/07/clap-switch-with-ic741-and-cd4017.html
rconde3 (author)2014-02-28
Can you please send me the clear circuit diagram? thanks rkconde08@gmail.com
vill.mendez (author)rconde32014-10-08
aimans (author)2014-09-28
a humble request for ckt digram... pls send on ashahapuri@gmail.com
vill.mendez (author)aimans2014-10-08
dhevilizh (author)2014-10-05
can also send me a copy of the Circuit Diagram at dhevilizh0624@gmail.com
and if you dont mind, also the Steps. thank you very much in advance
vill.mendez (author)dhevilizh2014-10-08
http://niotronic.blogspot.mx/2013/07/clap-switch-w...
if you need help ask me
ravenmandadero (author)2014-10-08
can you please send me the circuit diagram? thank you! raven_mandadero@yahoo.com
Did he send you the circuit diagram? If yes, could you send me the diagram? jorge9zeballos@hotmail.com Thanks!! :)
Jong.sarip (author)2014-10-06
could you also please send me the circuit diagram. Thnk you very much.
Shinnylildude@gmail.com
vill.mendez (author)Jong.sarip2014-10-08
vikkix (author)2014-07-27
hey could u pls send the schematic to my email address (vikkix7@gmail.com)
vill.mendez (author)vikkix2014-10-08
neeraj.ratnawat (author)2014-09-24
can you please send me the circuit diagram at
neerajratnawat@gmail.com
Ploopy (author)2014-02-24
Cool!
Could you please send me a clear picture of the circuit diagram luigi.pizzolito@hotmail.com
nice instructable
zarmons (author)2014-01-30
hi you there,can u pls email me the schmtic diagrm?
zarmons_613@yahoo.com
AppleSliced (author)2014-01-20
Sir, can you please send me a detailed schematic diagram of this project..
Here is my e-mail "lorenzo.sanjuan500@yahoo.com"..thank you
nsingh25 (author)2013-10-19
bro can you email me a clear circuit diagram's picture email- nitish.singh604@gmail.com
hahmed7 (author)2013-09-17
can u plz send the perfect circuit diagram to my mail plz. My mail id is ha300101@hotmail.com
vdps007 (author)2013-07-20
can u plz send the perfect circuit diagram to my mail plz. My mail id is vdps007@gmail.com
About This Instructable
27,889views
49favorites
License:
Bio: Interested in different things i could possibly make.
More by souichi:T.A.P BOT  (Touch Assist Player )Cotton candy machinePastillas De Leche (Philippine soft milk candy)
Add instructable to:
