Introduction: Clap-on Lights With Tessel
Picture of Clap-on Lights With Tessel
Tessel-Clap-Switch
Tessel listens for a clap, then toggles a relay to turn something on and off.
(Also view this project/get the code easily at the Tessel projects page)
You need:
To use:
  1. Clone this repo
  2. npm install
  3. Connect lights to Relay Module in Relay port 1
  4. Plug in modules to Tessel: Relay in port A; Ambient in port B
  5. Plug in tessel via USB
  6. Plug in power to lights/relay
  7. Run "tessel run index.js" from this folder in your terminal
  8. Clap! Watch the lights turn on and off.
See it work:
On vine
Step 1: Plug in Wires to Relay Module
Picture of Plug in Wires to Relay Module
A relay acts as a switch– either connecting ('on') or not connecting ('off') the two wires fed into the channel.
Use a pen or a nail to press down on the top of the relay, and feed in the red (power) wire.
The ground wire doesn't go into the relay; it just goes straight to the power adapter.
Step 2: Plug Modules in to Tessel
Picture of Plug Modules in to Tessel
Relay gets plugged into Port A; Ambient gets plugged into Port B.
Step 3: Plug in Tessel to USB
Picture of Plug in Tessel to USB
Plug in the Tessel to your computer. This provides power and lets you push code.
Step 4: Plug in Power to the Lights
Picture of Plug in Power to the Lights
Step 5: Push Code and Clap On, Clap Off!
Picture of Push Code and Clap On, Clap Off!
You can download my code from https://github.com/Frijol/Tessel-Clap-Switch. It looks like this:
// Takes a triggering value for ambient sound,
// toggles relay 1 when that trigger is hit.
var tessel = require('tessel'); var relay = require('relay-mono').use(tessel.port['A']); var ambient = require('ambient-attx4').use(tessel.port['B']);
// Sound level (0-1) needed to trigger. You may need to adjust this. var triggerVal = 0.22;
// When the module is connected ambient.on('ready', function () { // Set the sound trigger ambient.setSoundTrigger(triggerVal);
// When the sound trigger is reached ambient.on('sound-trigger', function triggerHit() { // Toggle the switch relay.toggle(1); }); });
  1. Clone the repo to get the code on your computer.
  2. From inside the directory, `npm install` in the command line to install the ambient and relay module libraries.
  3. If you don't have tessel installed already, `npm install tessel -g` so you have the Tessel command line tool.
  4. `tessel run index.js` to run the code on your Tessel.
  5. Clap! Watch the lights turn on and off.
Demo:
If you want to use it separately from your computer, you can run `tessel push index.js` and it will save the code in memory.
You can then disconnect Tessel from your computer, and power Tessel using any of the methods listed here. I plug it into the wall using my Android charger.
As soon as you provide power, Tessel will automatically run your code.
There are a lot of other things I could (trivially) do with this setup but haven't gotten around to:
  • Hook it up to a web interface so I can turn the lights on and off from anywhere with internet
  • Read ambient light data and automatically turn the lights on and off if it's dark/bright in the room
Verticees (author)2014-07-27
awesome!
Carleyy (author)2014-07-22
Cool! Have you used this in any larger projects?
SelkeyMoonbeam (author)Carleyy2014-07-22
Not the lights. I've been playing around with electrodes + Tessel lately: https://github.com/Frijol/Tessel-GPIO-EMG
About This Instructable
7,326views
137favorites
License:
Bio: An engineer, seamstress, cook, coder, and overall maker. Spent a summer at Instructables; got a degree in E: Neural Engineering at Olin College; made a ... More »
More by SelkeyMoonbeam:How to Build a Cabin Foundation in a Remote LocationOrienteering Using a Thumb CompassHow to Pack Hangers
Add instructable to:
