Introduction: Clap-on Lights With Tessel
Tessel-Clap-Switch
Tessel listens for a clap, then toggles a relay to turn something on and off.
(Also view this project/get the code easily at the Tessel projects page)
You need:
- Tessel
- Ambient Module
- Relay Module
- Lights and plug (or similar)
To use:
- Clone this repo
- npm install
- Connect lights to Relay Module in Relay port 1
- Plug in modules to Tessel: Relay in port A; Ambient in port B
- Plug in tessel via USB
- Plug in power to lights/relay
- Run "tessel run index.js" from this folder in your terminal
- Clap! Watch the lights turn on and off.
See it work:
Step 1: Plug in Wires to Relay Module
A relay acts as a switch– either connecting ('on') or not connecting ('off') the two wires fed into the channel.
Use a pen or a nail to press down on the top of the relay, and feed in the red (power) wire.
The ground wire doesn't go into the relay; it just goes straight to the power adapter.
Step 2: Plug Modules in to Tessel
Relay gets plugged into Port A; Ambient gets plugged into Port B.
Step 3: Plug in Tessel to USB
Plug in the Tessel to your computer. This provides power and lets you push code.
Step 4: Plug in Power to the Lights
Step 5: Push Code and Clap On, Clap Off!
You can download my code from https://github.com/Frijol/Tessel-Clap-Switch. It looks like this:
// Takes a triggering value for ambient sound,
// toggles relay 1 when that trigger is hit.var tessel = require('tessel'); var relay = require('relay-mono').use(tessel.port['A']); var ambient = require('ambient-attx4').use(tessel.port['B']);
// Sound level (0-1) needed to trigger. You may need to adjust this. var triggerVal = 0.22;
// When the module is connected ambient.on('ready', function () { // Set the sound trigger ambient.setSoundTrigger(triggerVal);
// When the sound trigger is reached ambient.on('sound-trigger', function triggerHit() { // Toggle the switch relay.toggle(1); }); });
- Clone the repo to get the code on your computer.
- From inside the directory, `npm install` in the command line to install the ambient and relay module libraries.
- If you don't have tessel installed already, `npm install tessel -g` so you have the Tessel command line tool.
- `tessel run index.js` to run the code on your Tessel.
Demo:
If you want to use it separately from your computer, you can run `tessel push index.js` and it will save the code in memory.
You can then disconnect Tessel from your computer, and power Tessel using any of the methods listed here. I plug it into the wall using my Android charger.
As soon as you provide power, Tessel will automatically run your code.
There are a lot of other things I could (trivially) do with this setup but haven't gotten around to:
- Hook it up to a web interface so I can turn the lights on and off from anywhere with internet
- Read ambient light data and automatically turn the lights on and off if it's dark/bright in the room
Home Technology Contest
Epilog Challenge VI
