Claw Machine Picker-Upper
13,983
173
12
Posted
Introduction: Claw Machine Picker-Upper
Claw from arcade machine on a stick with a handle for picking stuff up.
October 2013
https://www.tindie.com/products/marc_cryan/claw/
*** September 2013  **
I have a project running on tindie.com   for a real claw machine kit.
**** Kickstarter ends July 2nd  *****
Here is a video of it in action:
Step 1: Get Stuff
The main thing is the claw.  I had a hard time finding these and had to go to a supplier in China.
I've posted them on amazon here:
Claw Machine / Crane Game -- Actual Claw  (note: this is a link to my own thing on amazon.com)
The other parts are:
  • 1" PVC pipe
  • Stiff wire
  • A spring (optional)
  • A nut and bolt (size 10-24, length is not critical, a  little smaller diameter is okay)
  • Electrical tape
  • Thin strips of wood - for handle (or something better)
  • Plumbers strap - for handle (or something better)
  • Black spray paint
Step 2: Take Apart Claw
The claw comes with some guts, a big solenoid, a string, and a cable.
  • Undo the two screws
  • Pry off the top cover
  • Remove the solenoid coil and string
Step 3: Remove Center Post
Undo the crew that holds the center post (that would be going through the solenoid)  to a metal triangle at the crux of the claw.
Step 4: Replace With Wire and New Bolt
  • Cut a length of stiff wire, maybe 3 feet, it should be longer than the final length of the picker upper.
  • Thread this through the hole created when you removed the center post and screw
  • Put a bolt in the hole
  • Loop the wire around the bolt, such that it is held in place at the crux
Note: this shows copper wire.  A stiff steal wire, 'mechanics wire' is better.
Step 5: Test That Out
When you pull the wire the claw should close.  Release the wire and it opens.
Step 6: Fit the Pole
A piece of 1" pvc pipe is used for the pole.  This one is about 2.5feet long.
The pipe has to fit snuggly in the body of the claw.  Wrap the end of the pipe with electrical tape until is is thick enough that you can jam it into the claw body and it will stay put.  Thread the wire through the pipe so it comes out the end away from the claw.  When you pull the wire the claw should close.
Step 7: Make a Handle
I used some strips of bamboo and plumbers strap to make the handle.  An actual plastic handle from a snow shovel or something would be better.
Step 8: Add a Loop to Pull On
Threaded the wire through a spring and twisted it in a loop to make a little loop to pull on... look at the picture...
Step 9: Test It Out
That should be it. Test it out by trying to pick stuff up.
If anything falls apart, add more tape.
Test Video:
Step 10: Paint
I painted the PVC pipe with black spray paint.
Step 11: Kickstarter?
I'm on the fence about putting this on kickstarter.  Alot of the work is already done but I'm not sure if people would be interested.
Here is a preview link: preview
Let me know what you think.
Thanks!
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
  • Gluten Free Challenge
8 Comments
nifty instructable. i did find claws a bit cheaper on http://www.gamespareparts.com/html/product__1178.html
too much green..aka money
Yeah I know -- this is pretty big claw, maybe I can find a smaller/cheaper one....
I can't get the video to show up.....
In YouTube, click the 'share' tab, then click 'embed' and copy that code. Then, paste that code into our editor with the 'embed media' button in the rich editor.
thanks -- the video shows up in the android app on my phone, it is just blank space using chrome on an ubuntu desktop pc .... must be time for an update.
