Introduction: Clay Ring Bowls
This is an easy and simple bowl that anyone should be able to make.
Step 1: Everything You Will Need:
Bowl
Different colors of clay (as many as you want)
Rolling pin
Greece proof paper
Blade
Nail polish or paint
Step 2: First
pick how many colors you want and roll them into thin snakes
Step 3: Then
Twist all the snakes together and roll around till the colors look how you like
Step 4: Next
It is time to roll it out so flatten it out a bit and place Greece proof paper over so t is easier to roll out
Step 5: Now
It has been rolled out remove the grease proof paper and lift from the surface
Step 6: Next
Place it into the bowl that you are going to use.
Step 7: Then
Use your blade to cut the edges so they are all the same height and then place the bowl into the oven and bake according to the time on your packet of clay.
Step 8: When
It has came out of the oven leave it to cool before taking it out of the bowl
Step 9: Now
We are going to paint an accent around the edge with nail polish or paint
Step 10: Once
You have painted around the top leave that to dry
Step 11: Finished
Now you bowl is dry everything is done and you can now use the bowl to store your rings or jewelry in.
Clay Contest
