3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cleaning A Knife
Cleaning A Knife
The knife, used for aeons by humans as a tool of war and a tool of craft. For centuries, humans have relied on a good knife for their survival. If it was dirty, the knife rusted, and if the knife rusted, they would be dead before they had time to make a new blade. Today, I'll take some time to show you how to go about cleaning a blade, so your beautiful $100 knife (see below) won't be a piece of scrap metal.
Let's get started!
(I am not responsible for any injury received following the steps of this Instructable)
Step 1Supplies
Most of the materials needed you probably have...You will need:
-A sink
-A dirty Knife
-Rotor Oil (Used to oil valves on trumpets, cornets, baritones, etc... easily attained at Sam Ash, or where brass instruments are sold.)
-An old rag
25 comments
Sep 15, 2011. 12:37 PMmcee2 says:
Thanks for the information about cleaning knives. My husband has a few gerber folding knives that he used to gut some fish. He usually washes them, but he had to go to a meeting and I got stuck with his dirty knives!
Dec 27, 2010. 10:37 AMBodhidharmaCharma says:
That's not a Kniofe, this is a Kniofe!
http://www.bladehq.com/cat--Benchmade-Barrage-Knives--407
Dec 30, 2009. 7:44 AMmayo291 says:
 Yes slicing your finger open would hurt but it would also get the knife dirtier.
Sep 28, 2009. 11:17 AMthewoodcarver says:
I know Schrade went out of business in 04 but are they gouging people this bad on these knives already ?http://www.knifecenter.com/kc_new/store_detail.html?s=SCH171UH
Sep 21, 2009. 4:33 PM15zhangfra says:
can i use cork grease or just vege-oil? i don't play a brass isntrument, and i doubt my friends would like me to go and clean a knife with their oil
Sep 22, 2009. 3:42 PM15zhangfra says:
thanks, i'm going to give cork grease a try though- if it doesn't clean it it can't break it because it's also used on oboe keys.
Sep 22, 2009. 3:43 PM15zhangfra says:
i don't have wd-40 or cooking spray though...
Sep 20, 2009. 4:02 PMKozz says:
I recently inherited some rather abused knives. One of them seems to be of a good make, but perhaps poor care resulted in dark stains and some mild pitting. There's nothing to be cleaned from the surface, it seems. Do you think that perhaps the stains and pitting can be remedied in any way, or at least somehow I can prevent it from getting worse?
Sep 21, 2009. 8:19 AMhailtothkngbby says:
I, too, inherited some rusty knives a long while ago. I found somewhere on the internet, the location escapes me, that you can wad up some aluminum foil and then wet it and scrub the blade. It takes surface rust off very well. I am not aware of any easy remedy for pitting though. To prevent it from getting worse, however, I would try a light gun oil. I usually use Remoil on my knives.
Sep 20, 2009. 10:50 PMxfirexstarzx says:
I had a few knives with the same problem. The most mild solution I've tried that worked (this sounds sorta stupid, but bear with me) is to stick the knife into an onion (cover the whole blade) and leave it there for a couple days. Take the knife out and wash it off, then oil it. It took the stains off from some of my better used hunting knives. If the onion trick isn't enough, fill a cup with white vinegar and suspend the knife so that just the blade is in the vinegar. Make sure ONLY STEEL is in the vinegar as it will eat softer metals. Check the blade every day. Remove all black deposits with steel wool. All of the rust should be gone in a couple of days. Clean, oil, and polish your blade. Although these methods remove the rust, there is no remedy for pitting (that I know of). The best you can do is keep the knife oiled to keep it from rusting more.
Sep 20, 2009. 1:38 PMlemonie says:
Which is cleaning the blade - oil or water? (Or is it both?) As far as I read this, the last step on the blade (6) involves wiping it with a damp-cloth, how do you ensure it's dried to a non-rust degree? And have you any tips for removing rust? L
Sep 20, 2009. 8:04 PMmockingbirdthewizard says:
oil does a good job of cleaning the blade when buffing with the cloth it takes off light rust and leaves a light coat of protection on the blade. the water is mostly to clean the oil off.
I will often wipe the knife down with a silicone cloth as the last step as it leaves a level of protection on the blade. like this: "http://www.cabelas.com/p-0059412290680a.shtml" I have no idea how long they last, but I've been using the same one for 6 months and it still does the job. my cloth is also a different brand, cabella is a brand name. my guess is they're mostly the same.
Sep 20, 2009. 3:32 PMCoffee bean says:
Water cleans oil seal and prevents rust(i think). On a little rust use steel wool if It looks really bad hit it with a wire bush then sandpaper.
Sep 20, 2009. 10:58 PMlemonie says:
I'm not seeing the purpose of running it under a tap, after being sealed. Does this not work as well if you oil - wipe- oil -wipe, or is wiping the oil with a cloth something to be avoided? L
Sep 21, 2009. 11:37 AMlemonie says:
Right, I get it thankyou. L
Sep 20, 2009. 1:22 PMscoochmaroo says:
If your knife is dirty from cutting and gutting, is oiling still the first step, or should you rinse it off first?
Sep 20, 2009. 7:58 PMmockingbirdthewizard says:
I wouldn't go from gutting right to the first oiling. a quick rinse and wipe to get the knife generally clean is a great start if it's coming from immediate use.
yep rinse, then dry, then oil.
Sep 20, 2009. 4:19 PMArbitror says:
This 'ible blew my knife cleaning 'ible out of the sky... Yours even got featured...
O well! You did a good job! This is a five star(er?) for sure! *****
Sep 20, 2009. 4:04 PMgreybunny says:
Oil removes surface rust
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Future filmaker
Keep and eye out Hollywood, Cause I'm comin'!
