3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Clean Greasy Hands With Lotion - The Poor Man's Gojo
Clean Greasy Hands With Lotion - The Poor Man\
To clean dirty greasy hands, slobber lots of skin lotion onto them, work it around, and then wipe it off onto a rag. Most of the dirty grease will come off with the lotion.
Technique demonstrated by Star.
To make it work even better, before starting your dirty work, rub lots of lotion into your hands .
Especially work it under your nails. In the cleanup phase, an old toothbrush works great for cleaning fingernails.
Step 1Work It In
Work It In
In theory oil and water can't mix, and we're mostly made of water, but somehow dirty grease really likes to stick to human hands.
The lotion contains emulsifiers such as lecithin that make it possible for oil and water to mix.
So the wet lotion greedily mixes with the dirty grease and loosens it from your hands.
31 comments
Oct 10, 2011. 8:23 AMKittyF says:
butter costs 4 dollars a pound. not happening in this lifetime. teehee
although you're right, in a pinch any grease/oil/lotion will work to loosen machine grease. machine grease is much heavier and what you're doing is using a lighter (not to mention-CLEANER) oil to thin it out and make it come off on the rag easier and more completely.
you could even use machine oil to loosen it, but machine oil drys the skin I think.
Dec 13, 2010. 9:19 AMprosoap says:
Prosoap is a great soap for hands that work!
http://prosoap.blogspot.com/2010/11/real-man-have-soft-hands.html
Sep 29, 2010. 2:30 PMDIYCharlie says:
If you're doing any painting, especially with a sprayer, apply some lotion to your hands, arms, sprayer, watch, facial hair, before starting. When you're finished, the paint just wipes right off the the most part. Areas where the lotion can be rubbed off will not fare as well.
Jul 10, 2010. 7:44 PMdesya says:
I have been telling trick to my friends for years....like after checking their cars oil.... most women have a small bottle of lotion in their purse... always good to have on hand...and paper towel to rub extra off
Feb 13, 2009. 9:24 PMrat_bone says:
Another cheap way to clean really greasy hands while working on motor vehicles is to use a little motor oil (even used oil). Put a little on your hands and rub them together. The oil loosens the grease quickly and easily, then just wipe the oil and grease off on a rag and wash your hands with soap and water to remove the oily residue.
Jun 6, 2010. 11:56 AMjohnny3h says:
I agree. I've used motor oil [both fresh and used] for heavy grease and grime removal from my hands and it works great. I'm glad you mentioned the need to wash the oil residue off of out of you hands because over the last few years it has become well known that motor oil can be absorbed into the body through the skin, and removal with soap an water is the only sure method of avoiding the contamination. Also, I've read that the "used" motor / crankcase oils are loaded with harmful compounds, AND micro particals of engine wear metals!!!!! So, as rat_bone indicates, IF using motor oils to clean hands, be sure to follow immediately with thorough hand washing with lots of soap and water!!!!!
May 21, 2010. 8:34 AMUna says:
Crisco works great for this.
Aug 21, 2008. 6:16 AMClayton H. says:
My dad works at a place that is really greasy and he lets me use the cool metal cutting tools for projects. well anyway I get really greasy and he has a special soap called "magic soap" which is just soap with sand in it and it works like a charm.
Aug 4, 2009. 1:14 AMloppy96 says:
i use coffe grounds mixed with dawn gets out all the gunk used coffe grounds of course
Nov 8, 2008. 8:39 PMturnerfromdh says:
its also called lava soap
Jun 6, 2009. 10:48 PMYerboogieman says:
Works great.
Jun 7, 2009. 3:33 PMClayton H. says:
Now my High School woodshop has this stuff called "cherry bomb" works well and smells like cherrys, mmmm.
Feb 9, 2009. 3:56 PMzero838 says:
yea its called "lava soap" or "fast orange" is another one
Nov 19, 2008. 6:51 PMtechnodude92 says:
is that the stuff that's red with the pumice in it? I've seen it in the local publix and was tempted to buy it.
Jan 24, 2009. 8:35 PMturnerfromdh says:
think so
Jun 6, 2009. 10:41 PMYerboogieman says:
Well, you forgot about the oils on your skin.
Apr 13, 2009. 1:35 PMyanggers says:
Most elegant! hands feel great after degreasing! I will try this (and other methods suggested in comments) on cleaning the bike chain drive!
Nov 25, 2008. 6:51 PMgoogbar says:
My best trick is using regular soap + a luffa sponge... This is great!!! The secret is to rinse the luffa from time to time. Black greasy paws become nice clean and good smelling hands
Nov 25, 2008. 6:33 PMFast Eddie says:
Great idea here. I'll have to try this next time. Up till now, the best Ive found is just plain old powdered laundry detergent. Tide, Sunlight, whatever... Old timer machinists trick. Any old shop will have a small dish of Tide beside the sink. Seems alot more sensible than mixing sand (dirt) with soap to get the same result, eh? ;)
Nov 18, 2008. 9:55 AM2ManyProjects says:
I used to use dishsoap, but it was seriously drying out my skin. I think I will try lotion next time. Thanks!
Nov 13, 2008. 2:20 PMthylacine says:
When I worked in a printshop, rather that clean up oil based inks w/ solvents, we would use vegetable oil and rags for the initial cleaning, and then simple green or some other strong detergent to clean up the oil residue. Worked very well and much better than a petroleum based solution.
Aug 6, 2008. 8:09 PMjedij585 says:
The best grease cutter for hands after working with oil is liquid dish soap. It is made specifically for cutting grease from dishes and works awesome on skin as well.
Jun 30, 2008. 9:28 PMZengineer1618 says:
Baby oil works really well too for removal of oil / grease from hands. It also removes some sticky residues that are left from some of types adhesive tapes and labels.
Oct 28, 2007. 1:38 PMflactemnad says:
Baking soda + soap is my favorite for greasy hands. The baking soda will quickly break down the greasyness, soap is good for a little more cleaning power. It's a bit drying on the skin though, so a little lotion at the end is a good idea too.
Sep 8, 2007. 8:45 AMcarpespasm says:
i've made homemade gojo with play sand and a gallon jug of hand lotion before. worked well and was much cheaper than a gallon jug of gojo.
Aug 20, 2007. 8:16 AMOhm says:
Yeah I think the lotion well end up costing a lot more to essentially waste cleaning you hands. By a bar of lava soap if you only need it on rare ocations, you well need the lotion after that tough. Also there are products that you can apply to your hands and arms before hand that help keep the grease from sticking as badly, often called by the generic name of liquid gloves.
Aug 19, 2007. 9:31 PMSintax says:
Seriously try olive oil next time, It gets rid of grease very fast.
Aug 20, 2007. 4:59 AMzachninme says:
Then you're left with oily hands! D:
Why not just wash them with soap?
Aug 19, 2007. 6:48 PM!Andrew_Modder! says:
just stright up lotion? i prefur dishsoap. also did you know you can find GoJo or Lava-(like GoJo) at doller stores?
Aug 19, 2007. 5:40 PMWeissensteinburg says:
If you include videos of you singing a few different mechanics songs, I'll give you a +
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1249
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
