I had the misfortune of spilling some Mountain Dew on my keyboard about two years ago, and this method has kept my keys working smoothly ever since. Cleaning your laptop is simple, but time consuming. Take your time and don't try to force anything and you should have a perfectly functioning keyboard once more!
Click the "i" in the upper left hand corner of any picture to view the full resolution file.
56k beware, most of these files are 4-5 MB.
For any sticky situation, following these steps will make your keyboard work and feel like new!
Step 1: Shut Down... Fast!
Your first order of business is to shut down your computer and remove the battery - as quickly as possible if you spilled liquid on it. Force shut down your computer by holding the power button until it turns off. Any data loss during this process should be minimal and less costly than any shorted-out hardware.
Step 2: Gather Materials
- A cup or container large enough to hold all the keys on your keyboard
- Rubbing alcohol
- Cotton swabs (Q-Tips)
- Dish soap (without bleach) or some other mild detergent
- Paper towels
- Flathead screwdriver
- Towel
Most of these supplies are probably already sitting around your house or apartment, but I doubt you'll spend over $10 if for some reason you need to purchase everything.
Step 3: Initial Wipedown
It's quite possible that you splashed liquid into every deep dark crevice of your computer during your spill. Use your cotton swabs if necessary, but don't worry about getting in between the keys, we'll get to that soon.
Step 4: Remove Keys
Your keys were basically snapped onto your keyboard at the factory... and therefore can be unsnapped.
Grab onto a corner of a key and firmly lift up. You may be required to pry on more than one corner at a time to unsnap each key. If a key (especially larger ones) prove difficult, wiggle a flathead screwdriver underneath the key and rotate the blade in several places to "persuade" it to let go.
If you spilled liquid on your keyboard, it will probably be necessary to remove the key carriers as well. My carriers are white and rotate to allow the keys to move up and down. These snap off similar to the keys, but yours may differ slightly.
This process will take some time, be patient and don't rush this part... that's a sure way to break something important.
Step 5: Clean Keys
I let my keys soak for about an hour.
Some of your larger keys may have one or several metal guide bars on their underside. These bars slide into slots on your keyboard, so make sure not to bend the bars or their slots on your computer.
Step 6: Clean Keyboard
Dip your cotton swab into the rubbing alcohol and begin to clean around each key post. Remember if any liquid made its way under your keys to remove the key carriers as well and soak them with the keys.
I found that some areas of the keyboard chewed up the cotton swabs fairly quickly. If this happens, remember to remove any cotton snagged off the swab before replacing your keys.
Flip your computer upside-down on a towel and give it about an hour to completely dry. If you are cleaning up from a liquid spill, let it dry at least overnight in case any liquid made it past your keyboard and into your computer case.
Step 7: Clean Keys... Again
Although it may not be necessary, I recommend going over the backs of your keys and your key carriers with rubbing alcohol the same way you cleaned your keyboard. Remove any guide bars and clean under these as well. Replace the guide bars when you are finished.
Step 8: Reattach Everything
After allowing time four your computer and keys to completely dry, reattach everything in reverse order that you removed it. Key carriers, keys, and battery. Test each key for function after you attach it. If a key still appears to stick a little, repeat steps 5-7 as needed.
Refer to the picture or drawing you made in step 4 when reattaching your keys. The keys and carriers just snap back into place, but make sure everything is aligned before applying any real pressure. Again, take your time and don't rush this part, you can still snap part of a key or try to force a key into the wrong place.
Boot up your computer and test out your keys on a word processing program. Make sure the letter you press on your keyboard is what shows up on your screen, it's very easy to switch two keys even if you were paying very close attention to their placement.
Step 9: Done!
If for any reason a key starts to stick again, repeat this process until it functions smoothly.
Thanks for looking.
Visit Our Store »
Go Pro Today »
Your guide was extremely helpful and I'm happy to say my keys are nearly good as new and still work! I've been having a lot of issues with random BSODs and general flibbity jibbitness while trying to beat this thing back into shape and it occurred to me that a ctrl key that may be stuck partially down while trying to install things could throw a wrench into the works.
I'm sure the machine is just gasping its last breath but I'm going to continue to do CPR until there's nothing left to be done. What's ironic is after I delicately beat this thing back into shape, I'm going to be handing it over to a five year old to play educational games on since those will run just fine on an older machine. I'm thinking she'll turn it back into poo in less than a month.
Anyhow. Thanks for the guide! Very helpful!!
THanks!
Assuming my comment isn't considered one...
