3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Clean and Grease your Skateboard Bearings
It's winter out there. The streets are covered with water, salt, and funky road grit. But you really want to skate. What can you do? Answer: go skate anyway, then clean your bearings so they'll live to skate another day.
This is a straightforward demo of how to disassemble, clean, grease, and re-assemble a skateboard bearing. Just in case you wanted to see it done. It's actually terribly easy if you've done it once.
Step 1What you Need
What you Need
Dirty skateboard bearings. (Can be obtained from within dirty skateboard wheels.)
Acetone or other solvent. (97% Isopropyl Alcohol is good too.)
A bowl or cup to put it in.
A small pin or straightened staple to remove the bearing shields.
58 comments
1-40 of 58next »
Apr 15, 2011. 10:17 PMzreed1 says:
Yea, I agree...... i tried wearing some gloves that i had just lying around, and it tore right through them. it kinda made my finger numb. so i MOST DEFINITELY SUGGEST WEARING GOOD GLOVES!!!!!!
Mar 14, 2011. 12:58 PMrhall-1 says:
It's probably a good idea to be wearing natural rubber or neoprene gloves (or something else that acetone won't eat through -- vinyl, latex and nitrile are no match). It's not particularly awesome to be using bare hands in that stuff, just sayin'.
Jan 3, 2011. 5:31 PMsharlston says:
Skateboardigs awesome,nice ible,have you seen element search and win? sign up now and ya can get decks clothing and bearings sign up now http://element.searchpluswin.com/refer/mattyts
Aug 7, 2010. 8:02 AMpaperclip32 says:
You can add that silicone lubricant works well too.Spray a light layer,and you'll have lubed bearings.
Oct 21, 2010. 1:22 PMsharlston says:
i like silicone but i struggle removing the stuff
Oct 23, 2010. 12:38 AMpaperclip32 says:
What type are you using?You need some spray silicone lubricant.
Oct 23, 2010. 1:01 PMsharlston says:
its rocol spray aersol type
Oct 24, 2010. 6:15 AMpaperclip32 says:
http://www.rocol.com/corp/index.php?option=com_content&view=article&id=66&Itemid=84&lang=en
That one?You're using food grade,no wonder.That's for baking.What you need is some Silicone spray used for gears and hinges.
I use this:http://www.3inone.com/products/silicone-spray/
Oct 24, 2010. 8:43 AMsharlston says:
Yes i have that,its reccomended for bearings:
"Precision Silicone Spray
Non toxic colourless silicone spray providing a light lubricating film with wide temperature stability.
Effective clean lubricant
Ideal for slides, bearings and conveyors
Resists oxidation and corrosion
Temperature range - 50°C to + 200°C"
Oct 24, 2010. 9:46 AMpaperclip32 says:
Hmm,I haven't used it before,but usually you're not supposed to peel it off.Try leaving it on and then going to skate.
Oct 25, 2010. 3:27 PMsharlston says:
peel it off?
Oct 26, 2010. 1:22 AMpaperclip32 says:
You said "removing the stuff" so I deduced that it formed a layer over the balls.
Mabye it doesn't.This conversation is going nowhere.
Oct 26, 2010. 4:35 PMsharlston says:
I meant removing the silicone lube from the bearings becuase i was switching lubricants
Aug 20, 2009. 2:09 AMsharlston says:
(removed by author or community request)
Nov 13, 2009. 9:14 AMPlaid Demon says:
you have the best on market
Jan 10, 2010. 9:03 AMsharlston says:
wtf why did my comment get removed seroiusly are abec 1s best on the market?
Mar 15, 2010. 6:21 AMAndy-K says:
 Not so much. Abec 1's are the lowest bearing in the ABEC rating. The best on the market would probably be the bones swiss, or labyrinth.
Apr 7, 2010. 3:05 PMsharlston says:
so why did plaid demon say they are
Mar 30, 2010. 2:50 PMkoebwil says:
Actually the Abec scale has very little relevance to skateboarding since it does not take side loads, materials, or the surface finish on the races into account.  It only defines a tolerance for sizes and sphericity, or at least that's how I understand it.  It might tell you how accurate the shop that made the bearings, but not how well they will really work.
Apr 14, 2010. 3:54 PMgofast845 says:
i have abec 7s there the top notch stuff pretty cheap two give em a shot
Apr 7, 2009. 12:41 PMjjjjake says:
is it safe to touch the acetone with bare hands?
Feb 14, 2010. 6:10 PMDesty Nova says:
Yes, it's ok, just feels really cold as the solvent evaporates via an endothermic reaction. If you keep doing it on a prolonged basis, your skin can get dry though. Also be careful not to spill it on plastic which might melt or blister (like a computer keyboard).
Jan 17, 2010. 2:08 AMsharlston says:
what bearings are they?
Jan 10, 2010. 9:02 AMsharlston says:
in the pic on step 3 is the amber coloured stuff grease or ball retainers?
Dec 30, 2009. 1:09 PMsharlston says:
Aug 22, 2009. 9:53 AMsharlston says:
also some other good oils are: lithium grease synthetic oil (mobil 1) really thick veg oil(last resort) the gunk from a bike chain(works perfect if you can get it without dust i made a plastic bearing by replacing the normall bearings with airsoft bb's want to see a pic?
Dec 30, 2009. 9:37 AMDarren. says:
yeah post a picture
Dec 30, 2009. 1:05 PMsharlston says:
here
1st pic bearing with no grease
2nd pic packaging
3rdpic fully packed with grease
Dec 30, 2009. 9:40 AMsharlston says:
will do
Jan 1, 2010. 10:30 PMDarren. says:
i cant see the piture/ post a lnk or something
Jan 28, 2010. 2:49 AMsharlston says:
could of been  a bug ,here:
Feb 3, 2008. 9:45 AMGorillazMiko says:
Thanks! I might try this out, my bearings are getting all weird. My friend used to put WD-40 on his. It works, but you will have to do it over and over again. This is way easier, awesome Instructable. +1 rating.
Dec 6, 2009. 11:57 AMsharlston says:
what you mean by all weird?
Mar 9, 2008. 3:34 PMsploge says:
never put wd 40 on bearings its a degreser and a rust remover and it disolves all that gunk which then get stuck and seizes
May 19, 2009. 4:37 AMspeedyspy2 says:
He's right
Oct 25, 2009. 1:55 PMMacaylastutorials says:
yes, some abec 5's have rubber sheilds, depending on what you buy, I have black widdow abec 5's and they have black rubber shields,
Sep 1, 2009. 2:28 PMsharlston says:
can someone tell me if abec 5s have rubber shields?
Jul 31, 2009. 1:10 PMrownhunt says:
My friend just buys new bearings there like $30 he just gets new ones once a year!
Jun 9, 2009. 12:12 PMadio says:
you should do full cleaning instructable since when i do it they ride like i first got them
May 3, 2009. 10:21 AMsharlston says:
ive got a cheap board and my bearings rattle should i replace them or something?
1-40 of 58next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
95
Author:The Real Elliot
