3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Clean and Grease your Skateboard Bearings
Step 5Grease and re-seal
Grease and re-seal
Add grease to the little pockets in-between the balls. Most people use just enough to barely fill three pockets. More or less (by a little) is ok. You don't want them packed, but you want all the balls lubricated.
Bike grease is fine. Marine grease will work. Silicone or lithium grease? Sure. Molybdenum grease? Overkill, but if you've got some lying around the house, you can use it.
Spread the grease around with your finger and roll the bearing back and forth until you can see all the balls adequately covered.
Gently place the seal back on. It will "snap" into place. Then, since you completely un-lubed it, run your greasy finger around the outside of the rubber seal just enough to keep it moistened. Also get some grease on the metal surfaces to help keep the rust away.
Note at this stage you could be using an oil instead of a grease. Good oils are Bones Speed Cream, Tri-flow, and other similar lubricating oils. Motor oil will work too. Bad oils include WD-40 and 3-in-1 (too light). If you use oil, 2 drops are usually enough. Spread it around by spinning the bearing and re-assemble.
1 comment
Aug 7, 2010. 8:02 AMpaperclip32 says:
You can add that silicone lubricant works well too.Spray a light layer,and you'll have lubed bearings.
Oct 21, 2010. 1:22 PMsharlston says:
i like silicone but i struggle removing the stuff
Oct 23, 2010. 12:38 AMpaperclip32 says:
What type are you using?You need some spray silicone lubricant.
Oct 23, 2010. 1:01 PMsharlston says:
its rocol spray aersol type
Oct 24, 2010. 6:15 AMpaperclip32 says:
http://www.rocol.com/corp/index.php?option=com_content&view=article&id=66&Itemid=84&lang=en
That one?You're using food grade,no wonder.That's for baking.What you need is some Silicone spray used for gears and hinges.
I use this:http://www.3inone.com/products/silicone-spray/
Oct 24, 2010. 8:43 AMsharlston says:
Yes i have that,its reccomended for bearings:
"Precision Silicone Spray
Non toxic colourless silicone spray providing a light lubricating film with wide temperature stability.
Effective clean lubricant
Ideal for slides, bearings and conveyors
Resists oxidation and corrosion
Temperature range - 50°C to + 200°C"
Oct 24, 2010. 9:46 AMpaperclip32 says:
Hmm,I haven't used it before,but usually you're not supposed to peel it off.Try leaving it on and then going to skate.
Oct 25, 2010. 3:27 PMsharlston says:
peel it off?
Oct 26, 2010. 1:22 AMpaperclip32 says:
You said "removing the stuff" so I deduced that it formed a layer over the balls.
Mabye it doesn't.This conversation is going nowhere.
Oct 26, 2010. 4:35 PMsharlston says:
I meant removing the silicone lube from the bearings becuase i was switching lubricants
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
93
Author:The Real Elliot
