Step 6You're Done!
Grease is nice because it needs maintenance less often than oil. On the other hand, it probably spins a little slower. Still, a clean and lubed bearing spins much much better than a dirty one, so it's good for you in the long run.
Note that you can switch back to oil when it finally stops raining and all the darn salt is off the freaking roads....
How often should you do this? It depends on how much you ride, and how often in crappy conditions. For greased bearings, try once every month at first or more often if you're in the wet a lot.
Oiled bearings need maintenance every couple weeks if you ride every day. I tend to clean them out right after a rain ride -- the oil just doesn't provide as much rust protection.
comments
Add Comment
Add Comment
