3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Clean and Re-finish Old Door Knobs and Hardware
The interior doors of my house have the original 1950's knobs - the old style with the long escutcheon plates and the knob-and-spindle doorknobs. When I moved in, they were painted over with multiple layers of paint, although the paint had worn off some of the knobs to show plain steel, with hints of the bronze colour they used to be peaking through.
I finally decided that I either needed to paint them over again, or clean them off and find a way to shine them up. So, here's how I made my worn and sad looking door hardware look like hammered copper for less then $10, and, made them all match.
If you're not sure whether there is lead paint involved, and you have children, or are pregnant, get the paint tested first.
Materials:
- your door hardware
- metal spray paint in the colour of your choice (I used Tremclad "Hammered Copper")
Tools:
- knife
- screwdriver
- slow cooker
- disposable metal container
- dish soap
- rubber gloves
- toothpicks and pins
- metal polish (I started with a commercial polish, but ended up using baking soda, water, and a toothbrush)
- surface to spray on
Step 1Remove the hardware
Remove the hardware
For an in depth look at how to remove this type of hardware, and how to clean its innards, I suggest this instructable:
http://www.instructables.com/id/Cleaning-and-Repairing-an-Antique-Mortise-Door-Loc/
The short version is:
1) Use the knife to carefully cut the paint along the edge of the escutcheon plates. This prevents large portions of the paint from coming with your plate.
2) If needed, use the knife to remove paint from the screw heads on the knob and plate - just enough the get the screwdriver in. The pin may also help.
3) Loosen the screw on the knob and screw the knob off the spindle.
4) Remove the spindle
5) Remove your plates
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Mar HK
