3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Clean your vintage IBM M2 clicky keyboard!
Step 2Remove the keys
Remove the keys
After the square bolts are done away with, take off all the keys! Oh, wait!! Not all the keys... Use a slot driver, start on the top rows, and pry from underneath to remove ONLY the SQUARE keys.
Once you have the square keys removed, your keyboard should look like the 3rd picture. At this point, remove all keys except the space bar, keeping in mind that they will have rocker bars that may need to be gently pushed out with a driver or lonely mismatched chopstick.
Finally, remove the spacebar. In the 4th picture you'll see a little plastic spring molded into the piece. With a driver, pull that one way and then the other, freeing the retaining post on either side as you go. Click on the picture for details. Then pry the spacebar out from the bottom, in the middle of the bar.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:bluescrubby(Gaijin Farmer--organic Japan)
