Dude is Your desk covered in permanent marker, pop, coffee, or anything else ?
Clean it Up !
All you need is:
-A spray bottle
-Rubbing alcohol compound (recommended) / isopropyl rubbing alcohol
-Lemon Juice
-Water
(This is my First instructable please leave comments)
Note:If you are using rubbing alcohol compound make sure it contains 95% ethanol. DO NOT DRINK IT ! IT CAN KILL YOU. I am not liable for damage to you or your property!
sharlston says: Aug 29, 2009. 10:52 AM
wd40 works on almost anything
swartley3ga says: Jun 5, 2009. 1:59 PM
just use toothpaste or softscrub on permanent marker...barely any scrubbing required and the "fumes" are minty lol
omnibot says: Oct 3, 2008. 2:39 AM
I'm trying this now.
cowscankill says: Sep 9, 2008. 6:13 PM
I just used this, but instead of for pens and stuff, I used it on my bathtub. I must say, THIS STUFF IS AWESOME! It got all the junk off my bathtub AND removed calcium build up on the faucet and knob. Thanks for posting this!
ehmbee says: May 17, 2008. 11:01 PM
Mix this 50/50 with Hydrogen Peroxide and it will get out any bit of muck that ever got into your car's carpeting-scrub with a brush and let dry-it is AMAZING.
Matt D655 in reply to ehmbeeJul 17, 2008. 6:30 PM
Hydrogen Peroxide is a bleaching agent not reaccomended on carpets
ehmbee in reply to Matt D655Jul 18, 2008. 4:12 AM
I think it needs an activator-when I used to bleach my hair (when I had some, lol), I had to mix bleach and activator-I have spilled out of the bottle peroxide from the drugstore on plenty of fabrics by mistake-no bleaching.....the hair stuff is different.
littlechef37 (author) in reply to ehmbeeMay 25, 2008. 12:30 AM
Interesting.... might try..... Little brats trample through the truck with there mucky shoes on....
ehmbee in reply to littlechef37May 25, 2008. 10:29 AM
It's really pretty amazing-I call it "Skizz"-that was the guy's nickname who told me about it. I keep it in an opaque bottle since peroxide comes in one, just in case it's light sensitive or anything. Maybe it does not need it, I don't know.
Sandisk1duo in reply to ehmbeeJun 28, 2008. 6:39 PM
yes, peroxide breaks down with light, probably with heat too
ehmbee in reply to Sandisk1duoJun 28, 2008. 7:48 PM
Well that settles it. I'll keep it in the dark bottle. I find it to be mild on whatever I'm cleaning but rough on the dirt.
Sandisk1duo in reply to ehmbeeJun 28, 2008. 9:48 PM
just wrap a bottle in aluminum foil, and your good to go, maybe
benstern says: Nov 19, 2007. 11:11 PM
PRO TIP: spray the back or your credit card with it and wipe!
Labot2001 in reply to bensternMar 23, 2008. 12:44 PM
Identity Theft Guy: Darn you benstern, now I can't steal anyone's credit card information!!!
altaria1993 says: Nov 21, 2007. 11:15 AM
doesnt this just dissolve a layer of whatever survace your putting it on?
littlechef37 (author) in reply to altaria1993Nov 21, 2007. 2:06 PM
it would depend on what your cleaning how much alcohol. it dose dissolve the layer of dirt. but your probably right the alcohol is basically and acid (correct me if im wrong)
pyro13 says: Nov 19, 2007. 10:10 PM
I like it! I use the same thing, but as a lemony fresh flamethrower!
zachninme says: Nov 19, 2007. 5:53 PM
What did you write the stuff in... it seems pretty resistant of the cleaner ;-P
littlechef37 (author) in reply to zachninmeNov 19, 2007. 7:32 PM
i wrote on my desk
killerjackalope says: Nov 19, 2007. 3:09 PM
yeah it's handy to have sitting about but after working in a small hot area with large amounts of isopropyl alcohol I found the dangers when my dad and I ended up really out of it, it was kinda like being drunk but not... But to testify for the uses of it in heavy duty applications, it can be used to do anything from stopping polyurethane resins from setting to starting the forklift on a cold (use the same as easy start and a spray bottle. Direct in to the manifold) Oh and if it was kept pure you can clean the gash in your arm from catching the fan in the engine bay with your arm...
!Andrew_Modder! says: Nov 19, 2007. 1:40 PM
ya that works well. For a wile now iv been using 92% rubbing alcohol with a teaspoon lemon extract in a spray bottle, cause you really dont know what rubbing alcohol does untill you use it! ;-)
littlechef37 (author) says: Nov 17, 2007. 12:02 PM
You got to scrub lots and if your cleaning permanent marker add more alcohol to the mix!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
