How many of us enjoy a quiet Sunday spending the entire day doing our own thing? How many of us would cherish an opportunity to do just that? This tutorial might be the answer you are looking for. Here are some ideas to help you get more benefits from your hard labour and help your products work better for you. Organizing your cleaning schedule can be very beneficial in helping you to do the things you enjoy so much . . . . a little more often.
Remove these ads by
Signing UpStep 1Organizing Your Time
•Pick one fifteen minute or half hour thing you can do two or three days a week during the week.
•Crock pot cooking has helped me a lot.
•Do a load of laundry in the evenings and fold the clothes while watching TV.
•Clean the refrigerator before you buy groceries. Maybe the night before.
•Clean rooms that are not used very much during the week.
•When cooking during the week cook extra for 1or 2 meals on the weekend and put it in the freezer.
•Have family members spend 15 minutes picking up the house every night during the week and reward them for their efforts.
•Make a grocery list and buy groceries after work during the week.
It really helps to be organized and committed.
CAT OWNERS: Cat's urinate instinctively in the same spot where they smell urine. If your cat is peeing on the carpet, the furniture or clothes, the chances of it continuing are very strong unless you actually completely remove any trace of previous urine. The best way to get your cat going in the litter box is by fully removing the stain and odor. There are several cleaners that claim to do this, however you are very fortunate if they work. Enzymatic cleaners are live feeding cleaners and tend to wear themselves out before they get to the heart of the stain. Anything that contains ammonia or vinegar is a MAJOR no-no for cat owners. The Humane Society even recognizes and advises against using these to remove cat urine. The reason for this is because they contain elements found in cat urine. If you use these items to clean cat urine, and they have the same elements in cat urine, you are only reinforcing your cat to urinate in the spot where you “cleaned” with it.
The next time you have this issue, first clean the urine with a paper towel and nothing else. Take that paper towel and place it in the cat's liter box. This will redirect the cat where the odor belongs. Next you have to fully remove the stain and the odor. This can be done with Genesis 950 as follows:
1. Clean stained area (furniture, carpet or rug) of any loose debris.
2. In a bucket, mix 1 part Genesis 950 to 7 parts warm water
3. Using a sponge, absorb the mixture of Genesis 950 and water
4. Squeeze excess mixture out of the sponge
5. With the sponge, wipe down any stained or dirtied area of the furniture, carpet or rug - do not wipe in a scrubbing manner, just gently wipe and let moisture from sponge absorb into the stain
6. Let the area you have wiped absorb the mixture - Genesis 950 is designed to work with water to soak into the stain and break the bonds of the stain, which then lift the stain from the surface. This is what will remove the stain and the smell.
7. After about 2 minutes the stain will be loosened and can be lifted from the surface
8. Empty your bucket and fill with straight water once you have cleaned all the dirty spots on your furniture, carpet or rug
9. Use a sponge with straight water to wipe off the cleaned areas
10. Allow furniture, carpet or rug to dry.
DOG OWNERS: Dogs are also instinctive in marking their territory and urinating. They develop a routine when going to the bathroom and every dog owner knows that dogs prefer to relieve themselves in the same spot. Even if they are going outside, they generally prefer to do their business in a familiar spot. If they begin to mark spots in the home, it is very important that you act immediately to remove the stain and odor to prevent repeated behavior. By removing the smell they have created in your carpeting, you are controlling the urge for the dog to repeat the unwanted behavior. This holds very true for puppy training as well. Genesis 950 is the perfect aid in training puppies not to urinate inside your home. By eliminating the smell from previous accidents, you are redirecting the instinct to go in that same spot. For spot cleaning, use the above mentioned instructions.
For larger stains, and a more professional look, clean your entire carpet using Genesis 950 in any steam cleaner. Use the amount recommended by the steam cleaner manufacturer as you would any other cleaner they suggest. Steam cleaning carpeting with Genesis 950 will make your entire carpet look and smell professionally cleaned. As the mixture of water and Genesis 950 are absorbed by the carpet, any stains, dirt or grime will be loosened. Germs and bacteria will be destroyed. Your carpet will be completely deodorized. After cleaning the carpet using a steam cleaner and Genesis 950, be sure to go over the area a second time with straight water. When you do this, you will see all the dirt and grim that the previously applied Genesis 950 loosened from the carpet.
You can get info on Genesis 950 at www.amerikalstore.com
I use a combination of spray bottle peroxide, activated carbon (I bought it in bulk) and silica sand for catboxes to keep their smells under control (it is hard because BOTH my males are very proud of their poo and refuse to cover it when they do their business in the catbox).
sunshiine
Sunshiine
Sunshiine
sunshiine
I discovered peroxide years ago when I had a couch covered in what was called "Haitian cotton" - rough spun, unprocessed stuff supposed to be dry-clean only. The reason for those directions was a natural yellow-brown discoloration that would come out of the chaff in the fiber and stain it all to heck once it was wet. I discovered that, if I humped the thing outside in strong sunlight, saturated it with 50-50 water and 3% peroxide, ran a steam/suction cleaner over it, and let it bake out there - turning all the cushions and such so they'd get sun as they dried - it would actually come lighter than it was. Woot. Glad those days are behind me. ;)
Is your cat fat or pregnant ..
by the way it is very sweet.
