3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cleaning Your Laptop Cooling System
My main computer is an hp zv5000 - it uses two heat pipes with heat sinks and two fans to cool the processor. Through use, those heat sinks (copper?) and pipes collect quite a bit of dust reducing the machine's cooling capacity.
If you don't have this specific machine, not to worry. Just use some common sense as the basic idea is the same.
Step 1Tools and Supplies and First Step
You'll need two things:
Q tips and a screw driver
First Remove your battery (possibly a duh! step, but just being thorough).
Unscrew the Ram cover - to make removing the rest of the case easier.
You'll need to remove the plastic cover just behind the battery 'cave' - remove any required screws and keep track of where they came from (some of mine were longer than average).
57 comments
1-40 of 57next »
Apr 23, 2011. 4:29 PMMomLes says:
You need to take the fan out and clean underneath it. My fan had wads of dust underneath that wouldn't come out any other way.
Dec 3, 2010. 12:32 AMJay Spannerz says:
I just got a laptop from an old teacher, 2005 ACER one, 1gb of ram, windows xp. I installed ubuntu and it's been lighter on the processor (celeron mobile, 1.4ghz) and ram.
Anyway, followed your tut (I'm a computer geek-o-rama but I was thinking twice about opening my first laptop) and I opened it all up, even took the cooling assembly apart. No wonder she was gonna throw it out (it kept turning off and overheating) this thing had no way for air to escape (dust-wise) So thanks :D
Jul 18, 2010. 10:10 PMusbdevice says:
i repaired identical hp laptop before, the pentium 4 M version. after years of heavy usage the thermal compound has 'frozen' makes it stick with the p4 chip (use penknife). reapplied thermal gel and it's as cool as new.
Feb 8, 2010. 11:29 PMtoome says:
i have done this 2 times and worked very well.. but this time i removed heat sink and cleaned a bit better.. but after reinstlled .. my computer turns on but will not boot any more ?? any comments ?? what went wrong
Feb 22, 2010. 9:29 AMbiire2u says:
Since this only happened when you removed the heat sink, you probably disturbed the processor and need to take apart again and reseat processor and heat sink make SURE you use new heat sink grease to attach. I did the same thing as you and what happened was the heat sensor in the motherboard claimed the processor was running 50C hotter than actual temp so it shut processor down. New heat sink grease fixed it
Jan 1, 2010. 10:46 PMbwpatton1 says:
LOL, I have a Pavillion ZE5200 and it is the NOISYist laptop I have ever heard, of course it has about five fans (literally), but at least it stays cool!
I just might have to use this instructable when I go to clean it out......
Feb 17, 2007. 7:23 PMCthulhu says:
Trebuchet: I just did this based on another instructable. When I did, noticed that I only have one fan, though I have the same back case as yours. I have a 5320 (I think). Wonder if there's any way to add a second fan... At any rate, I cleaned out my heat sink, and haven't had the fan stuck on for an hour like I did before. Great Post.
Jan 1, 2010. 9:51 PMoverheated says:
We had the same experience with the same model.  There is an open space where the second fan appears to be missing. There is a foam piece inserted where the heat sink would go and an open circular space where the fan blades would go.  I am hoping that this helps to solve our problem of shutting down. I think we caused the problem by leaving it sit on soft surfaces :(  Thank you for the step by step instructions. Very easy to follow and I learned something!
Feb 19, 2007. 11:15 AMCthulhu says:
The casing I have is identical to yours. I have the grating on the bottom and the side. Just no fan. Very strange. btw: sorry for posting twice; I thought that the comments were one common thread, so I re-posted my question on the first page.
Jun 3, 2009. 8:26 AMtoll_me says:
Hi, I have HP DV6000 laptop, does the same instructions work for them ?
Aug 13, 2009. 3:32 PMac-dc says:
There are several models of DV6000, look at the sticker on the bottom for the exact model. However, I had one in the DV6000 family and it does not have a fan housing cover, you have to take the ENTIRE laptop apart including taking the mainboard out to access the fan for dust cleaning. This was a very aggravating and poor design by HP for sure, from then on I always insisted that any laptop I buy have a removable fan cover panel.
Jun 10, 2009. 12:33 PMvinavil says:
You should really get the service manual for your laptop before unscrewing things at random. Just google "HP DV6000 service manual". I've got an HP NX6110, and the fan is accessed from the top, behind the keyboard. Very easy though, just three screws.
Jun 7, 2009. 3:09 PMLuizclet says:
Hello I am from Brazil. I liked this website very much. The information are very good. About this article "Cleaning your laptop cooling system" it is veru nice. I did like the information and it was very nice. The cooler of my computer was good again. Thanks a lot!
Jun 5, 2009. 6:43 PM247 says:
i cleaned my laptop off with an air compressor :)
Jun 3, 2009. 10:50 PMSinAmos says:
Jun 3, 2009. 3:17 PMmodern man says:
I have been using a small paint brushes & lung power to clean computer guts for a long time. Does a good job on crusty fans, and gets into small places.
Apr 2, 2007. 5:38 PMsecurity1 says:
question on a zv5000 hp, i gave this to my son and the video screen comes on sometimes and sometimes it doesnt.. tried all software issues, however video and laptop works fine on external monitorwith rear vga. does anyone know the common problem, harddrive perhaps, ram perhaps... before i junk it any advise would be appreciated...
Jun 3, 2009. 7:57 AMmac_daddy says:
Could be a loose video cable to the display or possibly fluorescent backlight problem.
Jun 3, 2009. 4:12 AMjuicebarjoseph says:
quick question, have you tried hitting the switch display button? It's usually Fn and one of the funtion keys (it's Fn and F4 for my hp pavillion zv 6000)
May 5, 2007. 9:04 AMwillh3 says:
The display will die altogether soon but very likely the screen itself is fine. Most likely, the problem is the inverter board that is contained within the display bezel. I just went through this with my zv5220. On line, you should be able to but a new inverter for about $40.00 and install it yourself. Its definitely worth the cost of the part, if your computer it otherwise ok.
Apr 3, 2007. 3:40 PMsecurity1 says:
thank you for your help. just black screen with nothing behind it. it happens when shut off and power back on, i try it several times and then screen will come on. i bought a new hard drive i will try that, there is no loose wire or screen disconnection. is the vga card and the video card one and the same, if it is the video card is fine.
Jul 11, 2006. 12:09 AMfungus amungus says:
I've heard that using compressed air on a lappie is bad news. Someone else might want to confirm that. Either way, some sort of vacuum would help.
Jun 3, 2009. 5:44 AMAudiyoda says:
Using compressed air isn't necessarily a bad thing - but you want to take two things into consideration. 1) - don't randomly blow the compressed air unless you can completely remove the bottom of the case AND get access to behind the touchpad and keyboard. 2) - make sure to hold down any fan blades when using compressed air. The bearings in the fan(s) are generally not designed to spin at super high speeds and compressed air will certainly make them spin faster that intended.
Jun 3, 2009. 3:40 AMle-Sid says:
in fact, the can of compresses gas you should use to help cleaning isn't compresses air. It's another gas, varying from the can manufacturer. Usually I got thethrafluorethane. I was said that compressed air (more than a regular compressor) would create condensation on the surface used, thus the bad idea...
Feb 24, 2009. 8:57 AMuberdum05 says:
I used compressed air on my computer CPU and it lived, the dust on it was a couple of centimetres on it!!!!
Jun 8, 2009. 5:45 AMthe_letter_7 says:
the affects of moisture and static shock can effect a computer, even if its not immediate. if it has a horrible crash a few months from now it could be due to this. but i could be completely wrong too, and it could be perfectly fine.
Mar 15, 2009. 12:03 PMscreenNamed says:
HP ZV6000 difference: the Computer does NOT have the ease of dissasembly that the zv5000 has, what worked for me was removing the cd drive bay first (single superficial screw), and then removing everything else. the whole bottom of the laptop comes off. I found out the hard way. but doing it again was a breeze. hope that helps.
Jun 3, 2009. 4:09 AMjuicebarjoseph says:
I had the same issue! Spent a half hour trying to find the last screw before I realised the CD drive came out.
Feb 26, 2007. 1:42 PMlemonie says:
I have a non-functional vacuum cleaner, which I'm thinking of adapting it for this type of precision cleaning (and fire-blowing). But for now I too use 'Q-tips'.
However, the muckiest machine I ever saw needed the gunk *scraping* off: years of smokes & cat-hair...
Jun 2, 2009. 6:16 PMmirathi says:
please do not use a standard vacuum to clean your computer. a standard vacuum will not protect the user from the potential danger of contact with electrical power and component damage caused by electrical discharge. a more safe way to clean your computer is to use a can of air or a box of q-tips...unless you can afford a 3m toner/electronic vacuum ($310.00) yikes!
Jun 2, 2009. 10:14 PMlemonie says:
How will it not protect the user any more than a can of "air" or Q-tips? (Notice that I didn't mention using a standard vacuum cleaner) L
Jun 2, 2009. 5:16 PMfwjs28 says:
congrats, you have been featured on lifehacker...
Jun 2, 2009. 3:07 PMPyrotechnic-Robot says:
wow that is so cool! have that same laptop! I just opened it up and cleaned it out. I am trying to remove the power on password do A know anything about this?
Jun 13, 2007. 5:06 PMkevincai96 says:
Do you have to pay for the new hard drive? I mean, there's probably a way to trigger the SMART alarm without having a broken drive.
May 5, 2009. 2:20 PMMonkaySquad says:
If you warranty covers it; then no. Like with my Dell, I paid for a the accident protection plan, which covers ANYTHING, so when my little sister split soda on my laptop and the hard drive became damaged because of it, they sent me a new one, free of charge. Plus I had to send my laptop new to have the heat sink replaced, among other things, and it was free of charge. And if they cant fix the laptop, they replace it with a brand new one. Best thing I ever invested in. I need to extend my warranty because I believe the heat sink needs cleaning/fixing.
Jun 13, 2007. 5:08 PMkevincai96 says:
Do you have to pay for the hard drive? I mean, there's probably a way to forge the SMART alarm.
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
323
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
