Introduction: Cleaning an Inverter.
Picture of Cleaning an Inverter.
My off grid home has inverters that work continously. Dust will build up inside them and preventative cleaning is mandatory.
Read in for how I clean my inverter.
Step 1: Removing the Inverter.
Picture of Removing the Inverter.
Turning off the circuit breaker to isolate the 24vdc supply, I used my Ratchet and 10mm socket to remove the lugs off the inverter. Also the ground and my custom control signal to the inverter needed to be disconnected.
The output for 120vac has to be unplugged. Next the two screws holding the unit to the wall removed.
Step 2: Opening the Inverter.
Picture of Opening the Inverter.
Four Phillips head screws hold the base plate. I turned on the inverter to discharge residual charge from the DC input capacitors. When the piezoelectric speaker died off I turned the inverter off. Now it is ready for cleaning. See how much lint and dust accumulated?
Step 3: Cleaning!
Picture of Cleaning!
Using a clean cloth soaked in Rubbing alcohol and a small paint brush, I carefully cleaned the dust from inside the unit.
Step 4: Completion!
Picture of Completion!
Once satisfied the internals were dust free, I reassembled the inverter and reinstalled. Now my home is using green renewable energy yet again!
About This Instructable
271views
5favorites
License:
Bio: As of April 2017 I have decided to no longer post on instructables. The fact that several of my published works have been removed without ... More »
More by Mjtrinihobby:External Light Sensor Night Light.Replacing a Toilet Tank Float Valve. How to Make Pig Feet Souse!
Add instructable to:
