3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cleaning and Repairing an Antique Mortise Door Lock
If you have an older house with knobs that slip, latches that are stuck inside the door, or other minor problems, then you should follow these instructions to remove the lock, dis-assemble it, clean and perform minor repairs.
Step 1Meet the mortise lock and door knobs.
This mortise lock set is installed in a 1930 colonial in the Boston area.
Notice the set screw on the base of the knob on the right. This screw should hold the knob securely to the spindle when you turn the knob.
34 comments
Apr 5, 2012. 2:37 PMbrowne says:
I have a sargent mortis lock 5131 and the leaf spring broke that holds the latch out. Is there somewhere I can find another leaf spring?
Thanks
Feb 28, 2012. 7:26 PMjmichaelkel says:
I have this same lockset in a door to a rental unti I am re-habbing. Where can I find a replacement threaded spindle (split halves), interior knob, and escutheon for the knob?
Mar 2, 2012. 5:28 AMskaar says:
in nova scotia, as recently as a decade ago, rods, crystal and plain brass knobs, even replacement locksets, were available in the nearby hardware store(national chain). there's a kind of lockset that has a push spring, a decent effort can be made by putting the spring from a click pen into them.
Feb 29, 2012. 7:43 AMjmichaelkel says:
Thank you for the response. Unfortunately, I live in northern California and there do not seem to be mnay sources for this old hardware. The old knob looked as if it had been cross threaded on the old spindle over the years and there is a lot of slop in the operation. The cam inside the lockset looks good. The spindle is split in two halves and is threaded There is a small downturn on one end of one half which looks to be some sort of catch at the cam side. The spindle is pretty badly bent which is why I am trying to find a new one. The replacement spindle and knobs which you can get commercially at places like Home Depot will not work. Also, the deadbolt I got to be functional but the small knob which operates it is also badly bent and affects its operation as theknob is turned. It looks like pot metal and I am afraid if I try to straighten it, it will snap. I plan to check a few places out today that I heard of - an antique store and a locksmith who has been around for awhile. If I luck out, it seems I have no recourse but to pull it out and plug or fill the door, then pep it for a current lockset and deadbolt. This would be unfortunate as the door I preserved and the lockset is pretty cool with the ornamentation of the handle and deadbolt.
Feb 24, 2012. 12:13 PMYokena says:
I'm so glad I found this site as I just might be able to solve my door lock problem.
I have locks on front & back door marked as "E-Z Mortise", made in Taiwan. They seem to be old and are made of mostly cast iron and brass. It may be that they are a copy of the old Sargent lock as they look very similar.
What I need is the brass cam, as shown in the third picture. The cam tabs are not the same, one being wider. The wider one is worn down to the point it no longer functions.
It I can't find the cam, I suppose I could have a machine shop build up the cam but it would probably cost more than a whole new lock!
Any advice would be appreciated.
Feb 10, 2012. 3:35 AMsoundgod06 says:
WD-40 IS oil.
May 17, 2011. 1:02 PMvcortlandt says:
Where can I buy one of those springs?
Jan 28, 2012. 5:21 AMstudiotanscott says:
i also need springs--did you find them?--scott
Oct 23, 2011. 12:56 PMdll932 says:
Believe it or not, those metal reinforcing strips that are in most wiper blades will work well sometimes. BTW, it helps to lay the lock chassis down cover-side-up on a table before you take it apart. Take pix of it once you open it so you remember which way everything goes together.
If it's a Sargent Easy-Spring, the hairpin spring attached to the chassis bottom up near the cylinder opening usually goes. You can usually make a spring for it "in place" by using the chassis as a bending jig, but it needs very narrow stock. You can narrow the stock by grinding carefully...just don't overheat it and ruin the temper.
Another thing that goes (in an outside door lock) is the spring in the cam disc that fits in the inside cylinder opening. Not all locks have these, but the ones that do rely on the spring to keep the cam in a neutral position. Otherwise, it can flip down and jam the bolt...usually in the locked position. it's difficult to replace that hairpin spring, so I usually replace the whole disc (found at your local 'smith).
If the lock has a key cylinder, there will be either one or two setscrews holding it in place (sometimes hidden under the edgeplate, or scalp as it's called). If there is only one, it has a LEFT HAND THREAD.
WARNING: Some newer mortise locks (like General and Schlage) have VERY strong springs in them and should only be taken apart with a special fixture that controls the release of the spring tension...or you may end up in the emergency room.
Jun 2, 2011. 5:58 AMvcortlandt says:
Thank you............
Jan 7, 2012. 9:00 AMn_b_c says:
this looks like a good site, so now that i have the answer to my mortise lock question, i,ll add my own tip:have any of you tried this?
we had a pair of big old double doors, with very worn/dropped non ball-bearing hinges. as they were 5 inches by 5 inches, replacements were not easily obtainable without waiting. we swapped the higes from top right to bottom left, and vice-versa. this not only brings the less used inactive door hinges over to the active [more wearing side], but the wear takes place on different surfaces, depending wheather the hinge is installed as left-hand or right-hand. if you draw it out you can see how the wearing points change left to right. it got us out of a sticky situation!--nbc
Dec 7, 2011. 7:46 AMjoldfield says:
I am repairing an older (1905 ish) mortise door lock. I cannot find a way to remove the knobs, there is no set screw, but what appears to be a metal dowel through the knob. Is there any way to remove the knobs without removing the metal dowel as I am not sure about the durability of the lock in general and don't want to damage it?
Jul 6, 2011. 10:04 PMn_toxic_ated says:
any experience with a mortise lock that has a set of buttons at the top that allow you to 'lock' the latch portion? that's what i have on my front entry door & now that i have it cleaned up i believe it's missing a part to help keep the spindle housing pieces in place (i have 1 piece with this task at the moment). the coil spring for the latch is actually on a post inside the latch itself, so my guess is i'm either missing a solid metal piece or possibly a leaf spring. my theory that someone LONG ago opened the lock box is somewhat confirmed by the fact that i believe the piece that holds the buttons in place was upside down when i took the lock apart. all the rest of the mortise locks in my house for the inside & side entry doors don't have this feature so i can't easily compare :-( she's a PENN Pat. Nov. 5 1912
Sep 29, 2011. 6:01 PMdll932 says:
You are missing a leaf spring that helps return the latch to the closed position; it runs parallel to the case bottom and pushes the "question mark" shaped piece toward the lock face. It looks like you are missing a hairpin-shaped leaf spring the helps retain the button position. If you want, you can disable the latch portion of the lock by removing the buttons and links. Penn is a very old name in locks, by the way.
Aug 6, 2011. 12:24 PMUtemike says:
I saw your note on finding a second lock. Did it have a different latch? The buttons on my lock are just as yours are, but the latch is solid with no spring. The pin that slides in the open space in the right end of your latch is instead linked to the latch.
There is a small leaf spring at the top of the enclosure that pivots the cast half circle and the latch to which it is linked back into the closed position. I can see hardware stores stocking replacement latches and springs when the correctly-sized little leaf springs were no longer available.
I'm not by the computer with the pictures right now, I'll try to post a clear picture later.
Aug 12, 2011. 8:17 AMn_toxic_ated says:
here's the 2nd lock i picked up (not yet cleaned). upon closer inspection i see 2 long, flat pieces of metal in the top right corner area, likely a broken leaf spring from somewhere, so who knows if anything else is broken or missing.
i'm also attaching a pic of one of my interior locks (not cleaned either, but clearly didn't get exposed to the weather!) with no coil spring either.
Aug 12, 2011. 8:05 PMUtemike says:
Glad I live in a dry climate! just spider webs and accumulated dust to clean.
You can see the leaf spring across the top of the enclosure.  It goes under the two-button locking mechanism, which is not sprung (back to original question).
Except for the solid vs slotted latch shaft your front lock and mine look very similar.
Sep 29, 2011. 6:03 PMdll932 says:
Looks like your leaf spring is upside down-it should be that lever against the case.
Aug 7, 2011. 9:47 PMn_toxic_ated says:
i'm not at home right now so i don't have the lock with me & i don't have pics on my laptop since i haven't cleaned it (yet?) so i'll take a look in a day or so.
Jul 14, 2011. 3:51 PMn_toxic_ated says:
all's good! i found another mortise lock with buttons at a nearby antique store & after comparing them i realize i'm not missing anything, except perhaps the skeleton key that fits into my front entry door lock (the key i do have fits/works better in the mortise locks inside my house). good luck when you finally take yours apart! (i took one of my inside mortise locks apart afterwards - a mere 7 or 8 removable parts vs almost 20 in my front entry lock!!)
Oct 1, 2011. 12:18 PMdrobinson15 says:
Any idea where one be able to find a mortise with a 3" setback?
It is labeled as D.M. & Co. from New Haven.
Jul 11, 2010. 11:29 PMaeray says:
Excellent 'ible! I've restored quite a few of these locksets myself (and even mortised replacement doors to accept original hardware. A good tip that you might add: to remove paint from old hardware easily, put the hardware in a crockpot, cover with water, add a dollop of dish soap ("washing-up liquid" in the U.K. I believe) set the crockpot to low and leave it overnight. Thumbs up!
Sep 29, 2011. 6:10 PMdll932 says:
Paint stripper will work if nothing else will. Make sure there is no paint in the openings where the bolt and latch come out and on those parts themselves. If there is rust, at least take a wire brush to it and blow the dust out.
Jul 17, 2011. 12:37 PMdll932 says:
WARNING! If it's a lock for an OUTER door, the spindle will be in 2 pieces. When you push the button on the lock face the OUTER knob is supposed to lock. If you screw the spindle halves together tightly (rather than leaving 1/2 turn of slop or more) BOTH sides of the door will be locked! Also, the split in the spindle is supposed to be in the vertical center of the lock-pay attention when installing and TRY THE LOCK WITH THE DOOR OPEN.
The usual reason mortise locks stop working is broken springs-one would do well to replace them all, if possible. A good way to clean out the lock body is with brake cleaner spray, followed by wiping with a paper towel. One of the FEW things graphite is good for is lubing the inside of a mortise lock body-if it has a cylinder for a key, lube with WD40 (or similar light spray oil) ONLY-no 3-in-1, no grease, no silicone spray.
Frequently the bolt will be bent from attempts to close the door with it extended. Being brass, they can be CAREFULLY straightened.
Painted hardware can be cleaned with paint remover and/or with a Dremel and rotating brush. The brass can polish up like new, but will have to be varnished or waxed after. NOTE: Some finished were purposely antiqued and won't like that way after polishing!
Sep 29, 2011. 10:49 AMrgrimm1 says:
Sorry, but NEVER use WD-40 in a lock. It is a penetrant, but will dry out and gum up rather quickly, attracting abrasive dust.
Use dry graphite only, use a Q-tip or puff applicator to apply.
NEVER use varnish if you can avoid it. It does not hold up as well as CLEAR LACQUER IMNSHO.
Large towns' locksmiths will (or should) have the correct key blanks to make up a proper set for the door(s). They will need to be cut to fit correctly! Many skeleton keys will NOT work, especially for entrance doors. Even the sellers of mortise locksets say that skeleton keys will fit MAYBE 30% of doors...and that does not mean they will work, just that they will fit.
One more thing: interior lock springs were of three types; flat springs, compression springs (often used on the strikes), and tension springs (used on the bolts, etc.). You CAN find close approximations at some GOOD hardware stores, auto supply stores, and GOOD locksmiths.
You will likely NOT find flat springs at most places. Locksmiths are your best bet, especially the older shops.
And why do springs fail? Because the lock dried out the lube or wore it away, and folks force the lock to work when it should be EASY...this is why other lock parts get broken as well.
Hope this helps.
Sep 29, 2011. 5:54 PMdll932 says:
Sorry to contradict. I have been a locksmith for more than 30 years. Much of that experience was rebuilding/repairing older residential mortise lock, some older than 100 years.
I have used WD40 for all of that time with great success in commercial, residential and auto locks, Example: I owned a car for 17 years. In that time I lubed the locks every 3 months with WD40 and they never froze or failed. Yes, it's a penetrant-with lubricating qualities. PBlaster, on the other hand has no lubing effect, and will cause locks to work HARDER immediately.
Graphite use hails from the time when locks only had large sliding parts with lots of tolerance. It still works fine with mortise lock bodies, but not in pin tumbler cylinders. I have seen cylinders so full of graphite they didn't move. WD40, on the other hand, will dissolve old oil and I have seen it immediately loosen up recalcitrant locks. I recommend it because it's easy to find and hard to overuse (it should not be used with most plastics-they may melt).
Varnish is OK as long as it's polyurethane-some lock makers use it as a finish.
"Skeleton keys" come in three patterns, one of which will open nearly all INTERIOR locks. EXTERIOR locks work on BIT keys, which must be cut by a locksmith (they have more complicated combinations since they contain more lever tumblers).
The majority of spring breakage I have seen was the result of rust or loss of temper of the steel.
Sep 29, 2011. 11:02 AMrgrimm1 says:
Caveat #1)
Use extreme care when removing the lockset from the door! It is likely cast iron or stamped steel. If cast iron, it will be brittle and can break easily if stressed. Often, the front brass face of the lockset is dependent on the case to hold it in place, and if the case is broken, you need to repair it.
A GOOD welder can BRAZE the thin cast iron section together again....do NOT use solder, it won't hold. And forget epoxy, it's a joke in this situation.
2) To remove the lockset, ALWAYS cut the paint away from the lockset using a sharp snap-blade knife or similar with a thin blade. This will cut the paint 'glue' holding the lock immobile...keep cutting until the paint is gone/cut free.
I then stick a hard dowel or similar in the knob hole, and use that to gradually work the lockset out.
3) Take a picture of the lockset with it out of the door.
THEN take a picture of it with the case open, but without removing any internal parts. This will give you a reference when re-assembling it later.
4) And this is important: Sometimes, the ORIGINAL installer of the lock will place a coin behind the lockset, with the date of the coin being the same year as the lock was installed. I find these every now and then....some dating back to the mid-1800's.
Save the coin. Re-install it behind the lockset when doing the install, and ADD a penny from that year you are working on the lock.
I sometimes add a short note on when I repaired the lock, what I did, and the name of the homeowner. And every now and then the household's kids get involved, and I have them sign the lock as a time-vault....they think it's cool, and it is.
Use acid-free paper.
Mar 27, 2011. 6:59 PMExiumind says:
Hi, do you think its possible to make a little enclosure just for that thing you are pulling on the photo and the spring?
I want a simple lock to go with my electric strike, plus the actual door complete lock..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:chriswren
