3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cleaning with Chemistry
Wouldn't you like to use simple cleansers that cost less?  Here's how to make heavy-duty cleansers with common household ingredients.  Let's use the magic of chemistry!
Step 1Foaming Drain Cleanser
If you've got gunk lodged in your drain, you can combine vinegar and baking soda to get a foaming cleanser.  Place the mixture of vinegar and baking soda in a bottle and invert to get a good foam going, then pour it into your drain.  Chase it with hot water.  This is best for dislodging softer clogs by foaming them apart.
1 C baking soda
3 C hot water
1 C vinegar
For a really heavy clog, use a funnel to pour the cup of baking soda onto the clog.  Follow with 1 cup of vinegar and let them react for 10 minutes.  Flush the whole thing with hot water.
What's happening?
The vinegar and baking soda are reacting to form carbonic acid, which then instantly breaks down into carbon dioxide and water.  The carbon dioxide bubbles out and creates the foam that forces your clogs apart.
7 comments
Aug 8, 2011. 8:23 AMmrsthursday says:
Hey thanks for this instructable! As a professional housecleaner I use this mix ALL the time. I guarantee it works like a dream and 'sweetens' the drains too.
I use bicarbonate or Baking Soda as it's known to clean a ton of stuff. Experiment a little, save a ton of money and you'll be quite amazed.
May 16, 2011. 10:38 PMlemonie says:
What is the acetic acid cartoon about? You've not mentioned ammonia in the text.
L
May 17, 2011. 11:47 AMlemonie says:
Yes, unfortunately you picked the wrong image for bicarb' - there should be 2 Na+ and two -ve oxygens. This is about chemistry so we should get it right.
L
May 17, 2011. 12:24 PMlemonie says:
Count the atoms: you're missing an H then.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:SpamDam
