3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Clear Rubber E-Gear Bags
They're great for carrying jumbles of electronics through airport security xray machines and capsized boats.
The rubber is limp, quiet, and doesn't develop pinhole leaks as much as stiffer materials.
It's quick to look through the side of the bag and see what exactly is in it.
I prefer them to a bulkier laptop case. If I want more padding I wrap a shirt around it.
I made these two bags for a trip to Indonesia a few years ago and have been carrying them ever since. The original plan was to protect my computer and electronics from moisture and humidity. To seal the bags up I rolled the ends up and tied them with a strip of the same rubber they're made of. I brought a kilo of reusable desiccant with me. The wet side of the big volcano in Bali was especially humid. It felt like it was raining off my eyebrows most of the time. I didn't end up spending too much time in super-humid areas and gave my desiccant to people who did.
None of my gear died on that trip, and from there I went on an outrigger canoe sailing trip in New Zealand. These bags were great dry bags for camping gear and food.
Now I carry them with me all the time. I don't bother sealing them, I just fold the ends over unless I expect boat troubles. One bag has my laptop in it and the other has my misc electronics.
I mislaid one of them recently and missed it a lot.
This project is pretty simple, but you can't buy bags like these and they're really nice to have.
Step 1Cut, Fold, and Weld the Rubber Sheet
I used 12 mil clear urethane rubber sheet from API inc. A friend bought the material for kitesurfing bladders, but it turned out to be way too heavy for that. If you don't mind PVC you could use your grandma's couch cover, or a clear shower curtain. Urethane is better than vinyl because it's more flexible and maybe less toxic to the planet. Polyethylene is too stiff, cloudy, and prone to fatigue. Don't use it.
Seattle Fabrics sells lots of coated fabrics that would work for this, and they specify which ones can be welded.
Some types of material will need to be washed with soap before you can weld them.
Cut a rectangular piece big enough to make the bag you want.
Fold it over and weld the edge with a hot iron.
Keep it from sticking to the iron by putting a piece of kapton (high temp plastic sheet) or tinfoil over and under it. Experiment with scrap material til you get the iron to the right temperature and get the knack of it. Rub the kapton on your nose to make it greasy and keep it from sticking.
Put a narrow stick under the edge you are welding on to keep from welding too far into the bag, and so you can put more pressure on the edge.
This is the same process (and picture) from Make Your Own Waterproof Camera Enclosure
29 comments
May 13, 2011. 10:24 PMpascals17 says:
Sorry to be a spoilsport, but as a chemist, I worry about people melting polyurethane. Upon heating, the carbamate linkages can decompose into isocyanates (the compounds from which they're made), which are one of the leading culprits of occupational asthma. Thermal decomposition of urethanes can also generate other nasty things like hydrogen cyanide. It's a cool project, but the worrywart in me compelled me to give you a heads up!
Jul 2, 2007. 10:25 PMPatented says:
i have a question...Why all this trouble to make a bag????why dont u just use ziploc???
Dec 16, 2007. 10:18 AMfrosty1433 says:
because this way the terroists can sneak the bomb on UNDETECTED
Dec 17, 2007. 4:45 AMPatented says:
The material inside the bag is not detected?
Dec 19, 2007. 12:09 AMfrosty1433 says:
you can sneak a small knife through a metal detacter by wrapping a lot of electrical tape on it.
Jan 19, 2008. 6:01 PMgamer says:
thats bull. the only way to pass a without it looking like a knife in the x ray, and metal detectors is by camoflageing it, putting tape on it will not help in any way, shape or form.
Jan 19, 2008. 10:56 PMfrosty1433 says:
how do you think they smuggle weapons into prisons? they wrap it in tape, and kiester is. sometimes they'll have females stick it up their vaginas.
Jan 20, 2008. 8:39 AMgamer says:
like i said, wrapping it in tape will do nothing, they have metal detectors in prisons. they make the weapons once theyre in the prison, they dont take them in. if they do, they bribe the guards.
Jan 20, 2008. 11:48 PMfrosty1433 says:
well. idk. i saw it on a movie.
May 14, 2008. 12:55 PMbaneat says:
If we got sigs, your idiocy would be sigged.
Jan 21, 2008. 10:50 AMgamer says:
if you see something in a movie, please dont just say it like "ya, im sure and i am ready to bet on it", do a little reasherch on the subject first.
Jan 28, 2008. 6:51 PMfrosty1433 says:
actually, I remember now... I saw it on the History Channel on a show about the Aryan Brotherhood.
Sep 20, 2009. 5:11 PMmasterochicken says:
I saw that. That was using Charles Manson's groupies though.
Jan 18, 2008. 11:07 PMalvincredible says:
lol this is why instructables is blocked at my school. -_- it says that this is a terrorits/militant group or something ahhaha :-)
Jun 14, 2008. 7:13 PMPatented says:
Go to kproxy.com to unlock it!
Jun 10, 2009. 7:26 PMReCreate says:
xproxy is blocked >_<
Jun 14, 2008. 6:07 PMabadfart says:
lol my school says its pornography
Jun 1, 2008. 2:31 AMReCreate says:
XD How far off!
Jun 11, 2009. 10:20 AMabadfart says:
ya we even had things blocked as educational
Jun 11, 2009. 10:40 AMReCreate says:
XD Yes that Is very Annoying
May 14, 2008. 3:18 AMSlothOnSpeed says:
If you have a relative that does scrapbooking, sewing or quilting, they likely have a teflon sheet and a miniature iron that can do the same job as the big one with a lot less hassle. (and for free) I use a teflon sheet for the same things as you use a kapton sheet (minus the nose-greasing), so I presume that it would be okay to use for making bags.
Feb 20, 2007. 2:52 PMminus273degrees says:
hi i wondered how much you paid for the plastic and if any one in the UK knows of somewhere to get the stuff
Aug 31, 2006. 7:34 AMbufiji07 says:
what kind of roll did you get. I can't fine it on API's site.
Aug 31, 2006. 7:58 AMradiorental says:
An alternative way of sealing this stuff up is vinyl glue
http://www.instructables.com/id/EWHO8U8064EP286D8P/
Aug 31, 2006. 1:46 PMradiorental says:
My tumors really dislike the taste of chewy vinyl glue (o;
Aug 30, 2006. 11:38 PMtheRIAA says:
"They're great for carrying jumbles of electronics through airport security xray machines." a homemeade rubber bag with a laptop inside... can anyone say.. cavity search?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
