So I Took apart my DVD Player(About 5 Years old, Does not play DVD's anymore, Note:Doing this Is Completely Undo-able) And Removed the Backlight and everything else attached to it, Until i got to the LCD, Then I Plugged it in and It Worked!
Later I Did it With an Old Laptop of mine(400MHZ 190MB of RAM, About 15 Years Old) And Was Pretty Impressed with the Results, I thought that I might Take Pictures But My Camera Is Really Bad, Its An IBM PC Camera, So Don't Expect HD Pictures or anything Close to that.
Well, be sure to Comment about it, And Tell me if you or someone you know has done this before.
(also, housepets? :3)
1 do not put a magnet near this tube
2 when you turn very very old tvs in another direction, the image disapears
why does the image disappear? well because the electrons are attracted to the earth's maggnetic field. to make it out of this magnetic field, you need to create another magnetic field, stronger than the earth's wich is why you have a big coil all around the screen part of your crt which is fired every time you turn on your crt.
so in response to your question no you cannot do this with a crt.
You can use an acrylic one way mirror,cut it to a custom size and have the mirror facing outward. The non reflection side should have enough glare to reflect the light better, you could also make the rim around the lcd panel have the mirror side inward and have 4 Cathodes for better reflection. You would also be able to see into the side of the screen from the outside, you could see people but they wouldnt be able to see you.
I know that one way mirror acrylic can be vacuum formed, im not sure of what would happen to its effect afterword though. If you could aford it, wanted to experament and what im going to attempt is disasemble the laptop and make molds of all the bottom casing so i can make a completly clear case. I'm also going to attempt to make one where the bottom is mirrored and you can see through the inside, like through the keyboard area as well as the screen, but when closed the entire laptop looks mirrored all around. If you have a cheep old laptop kicking around and money to mess around its worth trying it out, if it works you could apply this to a much better laptop for a good combination of aesthetics and performance lol.
One way mirror acrylic sheets
http://www.onewaymirrors.net/acrylic.htm
Cathode's
http://www.amazon.com/WHITE-CATHODE-BRIGHT-INCHES-COMPUTER/dp/B000JQ17WU
Cheap vacuform table
http://www.instructables.com/id/Make-a-good%2c-cheap%2c-upgradeable-sheet-plastic-vacu/
I like the idea, I have a alarm clock with seethrough LCD myself :P But the screen isn't really readable anymore, or is it still quite good?
it is simple :)
http://hackaday.com/2009/06/07/lcd-multitouch/
http://hackedgadgets.com/2009/05/16/multitouch-table-by-greenerbusiness/
oh and are you at school or something?
you could be at college
and are you wi-fi muching?
http://hacknmod.com/hack/how-to-hunt-down-wifi-leechers/
http://hacknmod.com/hack/screw-with-people-who-steal-your-wifi/
