Inspired by the simpler (and in a way, better) pen dispenser in the Guide to Field Soldering instructable.
Remove these ads by
Signing UpStep 1Parts and Tools
-a tooth pick
-small length of wood, 4mm x 4mm x 1" long is sufficient
-hot glue gun
-drill with a 3/8" bit
i know this is an oldish instructable so you've probably found your own solutions but i just found it and thought i'd share.
This Instructable is embarrassing compared to my recent projects
Anyways, your comment itself deserves to be its own Instructable!
i'll post it up at some point though.
Here, man, you see, I'm not from US or anything, so I do not know how do you call these, but it's fairly simple to use it, you just have to load if with solder, and in each click you'll have a bit of solder, as long the solder are the right size. I just lost mine so I can't give you a photo of that in the battlefield, but as long I buy one I'll send a pic for you to see...
Kepp the good work coming!
