Step 2The Gorilla Template
I hand-drew the original (see the scans), and you can do the same, or you can print off a copy of the scanned-and-drawn-over version I have attached as as a PDF. If you cannot see the full-size scans, don't worry. They are mainly an archive of the design process - the PDF file contains everything you need.
Notice that you need several layers of card - the torso and arms are made of three layers, the legs are one layer and the head is an added piece.
- I tilted the different layers of the torso at different angles compared to the ridges in the corrugated card. This made the finished model stronger than if all three layers were at the same angle.
climbing gorilla template.pdf(596x842) 104 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
